Hi , looking to hear from any users of the Samsung Galaxy a7 LTE , 3 GB / 32 . Appreciate it’s an older tablet now but have the chance of picking one up at a good price question is will this particular mini tablet run the latest DJI fly software / mini 2 combination ?
Not sure if it matters but would strip most of the existing software apps etc from the tablet to try give as much space etc.
So again anyone comfortably run the above tablet with the spec mentioned ?
Download the APK: Tap the Download Android APK button.
Allow installation: If prompted, change your tablet settings to “Allow installation from unknown sources” for your browser.
Install and run: Open the downloaded file to install the app, then log into your DJI account. [1, 2, 3]
Setup and Hardware Tips for the DJI Mini 2
Cable Length: The short RC cable included with the DJI Mini 2 controller will not stretch around a 10-inch tablet. You will need to purchase a longer, 30cm USB-C to USB-C cable to connect the controller to your Tab A7.
Mounting: The controller arms cannot hold a tablet. You must use a dedicated tablet mount adapter that clips into the controller handle. [1, 2]
Storage Warning: Your 32GB of internal space will fill up quickly. Go to the DJI Fly app settings and turn off “Cache When Recording” so video files don’t fill up your tablet’s local memory during flight. [1, 2]
Flying Performance Expectations
Live Feed: The 3GB of RAM is enough to handle the 720p/30fps live video transmission from the Mini 2, but you must close all other background apps before flying. [1]
Screen Brightness: The Tab A7 screen maxes out around 300-400 nits. It will be quite difficult to see in direct sunlight, so flying from a shaded area or buying a tablet sun hood is highly recommended.
Thank you so much the information is very much appreciated and glad to know it’s going to be okay to use .
Better than the little screen of the phone !
