hi all ,been flying my moblite 7 fpv for a little while …i noticed last time i keep seeing the RX LOSS and the drone dropped …just now , lovely evening , i took it out and tried it …twice i was dropped out of the sky both within 30m distance .
i will check any loose wire/ connection but checked on youtube and loads people advising to check betaflight , update firmware etc …i am all new to this and have not ever connected to pc , although was thinking i will have to when i need to set diff modes like ACRO , AIR . anyone here had this ? mine is just a standard moblite 7 and it came with this flysky FS-i6.
It’s not unusual for RX signal to be momentarily lost for a split secong, BF (andiNav) can cater for this by allowing a short time to elapse before it actions a ‘failsafe’
Look in the configurator here…Failsafe tab
What receiver is in it? If it’s an SPI Receiver then 30m is about its limit.
it is this 1 - Happymodel Moblite7 Ultralight Whoop Quadcopter – Unmanned Tech UK FPV Shop
- The lightest 1s AIO 5IN1 F4 flight controller
i must had it over 100meters before but only the last 2 occasions i started seeing the RX LOSS …i guess its me , with the crashes . i will take this opportunity to change the frame too . will report back after , thanks guys
Definitely an SPI receiver. They have limited range and the environment has a huge bearing on the signal strength anything between you and the drone will significantly reduce the signal strength and will cause a failsafe.
yeah , i can confirm that - DiamondF4 FS built-in SPI Flysky Receiver
My Tinyhawk freestyle 2 used to failsafe at anywhere between 30 and a 100m depending on the conditions. For instance if it had been raining the damp air used to play havoc with the signal. Same if I flew it close to wet trees.
my RX prob has been solved - new pack of 5 aerials arrived yeahhh
BUT now , 2 of my 650 1S battery wont charge probably due to long time sitting in the box! i now need to get a better charger to revive them . Anyone here use this 1 - SkyRC Imax B6AC V2 RC Battery Charger?
Yeah I have one, Never had any issues and it can charge most types of batteries
be careful of fake ones, I got mine from Amazon
thanks mate …ordered !
