I emailed the Hastings parks and open spaces team. This is their response.
Thank you for your enquiry.
You are correct that the relevant byelaws prohibit the flying of model aircraft and also prohibit activities that cause, or are likely to cause, disturbance. Hastings Country Park Nature Reserve is a nationally important site, supporting rare coastal cliff-top heathland and a wide range of protected bird and wildlife species. Habitat restoration and conservation management are also ongoing within the reserve.
Although the byelaws do not specifically refer to drones, we consider drones to fall within the definition of model aircraft. Consequently, the operation of drones is not permitted within Hastings Country Park Nature Reserve or over any other Council-owned land unless expressly authorised for Council business.
This restriction is in place to minimise disturbance to visitors, wildlife, and sensitive habitats. Drone activity has the potential to negatively impact nesting and feeding birds, as well as the enjoyment of other users of the reserve.
If you are seeking a suitable location for drone flying, I recommend contacting any local groups or the Foreshore Service to determine whether they can accommodate this activity in an appropriate area.
They have the catch all ‘model aircraft’ byelaw, however
Quieter types of model aircraft permitted
34. Bylaw 32 does not apply to any model aircraft which;
(a) Gives a noise measurement of not more than 82 dB(A) when measured
at a distance of 7 metres from the aircraft in accordance with the Code
I think the distinction here is that they will argue Hastings Park Nature Reserve is not Hastings Council. It’s like Kensington has no bylaws prohibiting drone flights, but Holland Park and Hyde Park do, both of which are considered in Kensington. It’s a tricky layer of bureaucracy .
Technically yes, but I’m using the term “Hyde Park” in the way that the vast majority of people do to also describe the area of land that is actually, Kensington Gardens. hence the “considered”. And given that all three are managed by the same organisation (Royal Parks) that also manage Brompton Cemetary etc. Anytime I need to look into the restrictions and contacts I am going to the same webpages over and over again.
I am pretty much getting sick of this: cause or likely to cause disturbance, don’t want to disturb the peaceful enjoyment of visitors.
Preferably stop asking these authorities as the answer is always the same.
If you have to ask about drones always ask about barking dogs, dogs off the lead, crying babies, fighting teenagers,
Also ask them if they’ve consulted the nesting birds and which they’d prefer; a dog looking for anything to chase or a drone passing over at 80m
Is a ridiculously vague statement that is vastly open to abuse. Someone wearing a football shirt of a team you don’t like or loud flatulance could be covered by this.
I flew in Hastings a time ago. I did check out the bye laws. I am going from memory so might not be accurate. The parks I remember did not allow take off or landing except landing in the case of an emergency??? I was very much aware of the areas where nesting birds were noted to the cliffs and would have stayed clear having respect for their habitate.
I would look at what has been published as if you email them they will give you worst case info bearing in mind the world tends to hate drones. Also Air Law tends not be be known to most officials in councils and often the police unless they consult one of their Drone Qualified Officers. The council may be custodians and control roads and carparks but they are public areas where people TOAL regularly. Bye laws generally only cover the Land as I understand it. PSPO’s may be more difficult such as the one around Wembley Stadium. You may find some of the posts by the “Black Belt Barister” on youtube very educational.
Having checked the actual Hastings Borough Council byelaws, my conclusion is that the council officer’s interpretation was too broad.
The nature reserves are clear: their separate byelaws prohibit powered model aircraft.
The ordinary council parks and open spaces are different. Their byelaws restrict power driven model aircraft, but then expressly exempt aircraft kept under effective radio control.
There does not appear to be another Hastings byelaw creating a blanket prohibition across all council owned land.
So I’ll be relying on the published byelaws themselves and the CAA rules, rather than the council’s general statement that drones are prohibited on all council land.
