This thread should be adequate … but, with recent changes in respect of memberships over the last three days, something unexpected might have happened.
Tagging @PingSpike … who will be able to check things are functioning as they should be.
It seems to be working now - maybe it just took a while to update.
I was literally looking at this issue right now
But… I couldn’t find anything wrong with you post count
When did you first spot the error @robintw ? Was it an hour ago when you tried to add a location for the first time?
Yeah that’s right, earlier this evening when I first tried. Just before I posted on here.
(I tried refreshing, logging out and in again, and then did the certificate thing with MavicBot that I hadn’t done before, in case that was needed).
