Hosting pano/360 photos
#1
@OzoneVibe was asking if GADC could potentially put something in place to host / share panos directly.
I’ve not used or taken any pano/360 photos apart from those taken with v1 of Hangar360 so I’m not sure what they actually consist of under the hood.
Does the DJI app just create a HTML file with some embedded CSS and 24 photos in the same folder or something?
Sorry for the recent downtime
360 Spherical Panoramas
#3
Some form of javascript would be required to control the pano.
This one looks promising: https://pchen66.github.io/Panolens/#Home
But would require the js and css files uploaded to the server.
#4
I’ve sent my web hosting guru a question asking if he knows the ins-and-outs.
#5
Are they unique to each picture? Or could they be hosted a static assets?
I’ll check out Panolens!
#6
They are just single files which would need to be included in a html file.
The pano image (equirectangular pano or cube pano) would need to be referenced in the html file for the viewer to display it, however, I am sure this could be passed in a query string to the html file and fetched in the JS.
I will have a play on my server to see if I can come up with a simple solution.
#8
Some kind of iframe plugin on discourse would work well allowing for the pano to be displayed in a post.
Here’s another js pano app that has it’s own CDN for the JS and CSS files: https://pannellum.org/documentation/overview/
I just threw this one up on my site, but my pano is large and may or may not show
https://dronescene.co.uk/pano/01.html
#9
Wow!!! It works for me!!!
#10
The panos need to be stitched by whomever has taken them, ideally into an equirectangular image with a 2:1 size ratio (mine is not 2:1 even though it kind of works) or a cubmap (6 images)
#11
The DJI Go4 app creates a 4000x2000 panorama jpg. (From the 360 mode, at least.)
#12
Want to try with this? It’s as created by the DJI Go4 app.
#13
Nice one
https://dronescene.co.uk/pano/2.html
Seems to work great
#14
Cool! :+1:
Even works ok on mobile browser. :+1::+1:
#15
May need to change the width/height attributes or make it’s size responsive when on mobile, but so far it looks like a winner.
#16
Looked fine in full-screen mode for me.
#17
Yah, full-screen is fine. Even uses the Gyro if you tap the little compass icon which is cool.
#18
So it does! Liking that!
Because of my mobile device / Android / Browser (Wileyfox Storm / Android 7.1.2 / Chrome) … your pano won’t load in mobile browser. I get a message images are limited to 4096 wide. :frowning:
In Firefox on same device, at least it downloads the file, but then says “Your Browser does not have the necessary WebGL support to display this panorama”.
Anyway - on a mobile device - 4096 is more than enough for someone to see what’s happening.
#19
25x lines of local HTML…
Amazing :smiley:
#20
Yah, not much to the default set-up. There are a fair few additional configs that can be tweaked, but for what we want I think it will suffice.
#21
Yeah, I uploaded 2, 1 of which I couldn’t open on my 5k set-up, which I created from the files that Hangar 360 saves when doing it’s pano.
I think the pano’s that DJI Go 4 creates are plenty good enough. They are 2:1 ratio too which is perfect.
#22
Tools like PTGui can output content for inclusion on your website, but they also output the viewer a web page and image (you can modify the HTML to point to other images etc). Here’s an example on my site http://www.jamesborden.me/photography/
Not sure how you would do this dynamically though…
