How do I re-upload modified photos to DJI SkyPixel?
I have created some images and i can view them when uploaded to dji skypixel
What I want to do is take the original images edit the images with the same file reference and copy back to the original folder to upload from my phone. I am not sure how or if this can be done. I can edit and create the 360 tiny planet in other software but there is no way I can see to load back to skypixel. Any one had any experience
Many thanks Bob
HI Bob
the answer is yes you can edit the original images, easiest way is to find the large jpg that has been stitched by the drone a big rectangle and use photoshop or similar to edit as you want then resave this.
If you want more detail you can edit every image that was taken and then re-stitch but this can be a pain and very time consuming
1-(unedited)
2-(edited)
Many thanks but how to then upload to skypixel?
I have been able to edit the images with a couple of different packages its the upload which has been the problem
Many thanks
