I would like to know how you can manually fly a Mini 2 in a relatively straight line and still change the camera direction (yaw).
I can do this to a limited extent with RTH with some planning. During RTH I can still Yaw and raise or lower my Mini 2 whilst maintaining a straight path… I would like to see a demonstration (YouTube?) of this if it exists… Haven’t seen one yet. My searches bring up the wrong type of videos.
I’d like to even try to Yaw but don’t know how to even start the practice… I’m a beginner with anything other that attempts at circling or in up down forward and back…
There are SO MANY Android devices, if they listed all of them it would be the biggest web page ever.
None of the three I’ve used over the years have been listed - and all worked fine.
Its a shame Litchi on the Mini 2 does not support Home or Course Lock as both modes are perfect for what you seek without the need for a preplanned flight
For a quick, onsite, solution, it’s only a few minutes to fly to each end of the line, and at the desired heights, to create waypoints and create a mission, then a minute to make any speed adjustments.
Upload and fly whilst the drone stays where it is.
But, yes, that is still “pre-planned” to a degree.
Done that a few times for steam train chasing.
A POI can be added as quickly, if needed - which it isn’t for chasing trains.
Use ‘Curse Lock’
Right stick up/down will fly you in a straight line and you can yaw to your hearts content.
also ‘Home Lock’ might suit as the straight line extends from your position
Steve
