How likely am I to ever need RPC-L1?
Hi all!
I’m in the process of setting up a small business to provide thermal imaging surveys using a Matrice 4T. I’m getting my A2 CoC, of course, along with training to qualify as a Thermographer.
That’s the absolute minimum I need to do the job, but the one I’m struggling with is whether I’m ever likely to need RPC-L1 qualification?
I understand that in theory it allows me some leeway with incidental overflight of people in certain situations, but if I still have to maintain 30m distance from people at take-off, which in many cases in the heavily built-up space I live in is likely to be completely impossible, whereas 5m under A2 at take-off is far more manageable!
My biggest worry is that I may come up against clients who insist on it because that’s what their operating manual says, even though it’s highly likely not really necessary, and in many cases might actually prevent a flight from taking place even though it would be perfectly legal under A2?
Hi Chris, I’ve considered doing the RPC-L1 myself as part of adding drone services to my business. From what I can tell, though, the A2 should be sufficient for most of the work I’m likely to be doing.
Clients don’t typically seem to ask for specific qualifications beyond the basics either, at least in the north where I am, so I’m not sure the RPC-L1 would really add much at this stage.
It is worth clarifying that having the RPC-L1 doesn’t turn an A2 flight into a Specific Category flight. You effectively have the best of both worlds; you can still operate under A2 where the flight meets the Open Category requirements, including the 5m separation in low-speed mode, while having the option to operate under the Specific Category where required.
The important point is that you can’t simply choose to classify a flight as A2 because it gives you better separation distances. If the operation falls outside the Open Category requirements, you have to operate under the appropriate Specific Category authorisation. The category is determined by the characteristics of the operation, rather than which qualifications you hold.
That’s pretty much what I thought, thanks!
Might be worth watching this. https://www.youtube.com/watch?v=6uKO4x6T71s
I took a look, but that feels more like it’s discussing GVC vs RPC-L1, whereas I’m wondering how likely I am to need either?
At the moment, I think I’ll press ahead with the A2 CoC and Thermography training, then go for one of those if I actually need to.
