I took this image of the Liver Building in Liverpool on a foggy morning. The image has only had a slight colour grade, but what I’ve never seen before is the image doubled up showing two of everything including the buildings in the background. Anyone had this before and what has caused it would the fog have had anything to do with it.
That is freaky. The buildings clearly look odd doubled up, but the clouds look perfect, so it really gives it a sort of haunting effect. Not intended I know!
Post up the original @barryb ?
This
can we see the original
It’s at times like that you wish it was a healthy bank balance, A Girlfriend ![]()
Is this a pano shot (ie multiple frames spliced together in the drone) or a single frame image? If its a pano shot, (and I’m guessing here) it could be that the drone image processor has become confused as to where the horizon is, because of the wooly transition from land to sky.
DJI_20250122083016_0056_D.DNG (93.5 MB)
Original DNG of the Liver Buildings.
The only solution I can think of is it was a bracketed shot x 3 and when merging one has overlayed over the other causing the distortion double take.
Uploading: DJI_20250122083016_0056_D.DNG…
Thanks for the reply Dave.
Cheers Wayne.
Hi Patrick, I think one image has overlaid over the other from a bracketet shot in post.
Glad you figured it out. Great image. Quite sinister with post colouring you did.
A definite ethereal look about it, very good.
Thanks Ian
