Is there anyway to improve the radio connection between drone and controller?
Lost my drone when it went out of control with an alert “RC not connected to mobile”
I’ve seen people using the controller with the built-in display, which has two aerials … I presume for better signals ?
Is there anyway to improve the signal for the DJI Mini 4k controller where you use your phone as the display?
I can’t afford the £800+ for the controller DJI Pro RC
Cheers,
SteveC.
Did you not have RTH set to activate on loss of connection?
That’s what it’s there for.
But, in any case, at what distance from you was the drone when connection was lost?
I have an older Mini 2 .. and connection isn’t a problem before the limit of VLOS is reached .. and a bit further.
The RC not connected to mobile is a phone to controller issue so I guess that the drone fly-away was down to lack of GPS signal on take off and the homepoint was somewhere else than its actual take off spot - so your drone went off to look for that homepoint as the controller disconnected.
If that is the case then improving the signal to the drone from the controller would not help.
Check the cable from the controller to the phone and ensure its plugged in correctly - you may need to take the case off your phone - I do when I use my controller with my iPhone as the plug dont sit correctly
things like being close to building with loads of WiFi devices will impact your signal as well tree’s in a forest.
It sounds like this fly away was just bad luck really :sad_but_relieved_face: hopefully your new drone wont have these issues. Generally speaking DJI signal to drone / controller are really good. My min 3 pro has never had an issue nor has my Neo ( though I hardly ever use the controller with the Neo as I use it as a follow me drone ) the only time I have had signal issue is with my Avata but then there was like 3 brick walls of a military pill box in the way.
Indeed. As per this ..
In that case you can still control the drone and fly it back to you.
Make sure its pointing at it
Do you have any airdata to share
Would suggest an cable/phone issue not a drone/controller issue.
My Neo does not do very well when the phone disconnects and you try and fly it back with just the controller for some reason - my original Mavic Mini ( way way back ) would do that but not sure why the Neo does it own thing when it disconnects - mmm maybe there are more bugs in the DJI system that we just don’t see as we hope to never see it.
My Mavic Pro, Mavic 2 Pro and Mini 2 all fly perfectly ok without a device.
Even taken off with the MP without a device because I couldn’t wait to switch it on, wait for it to boot and connect it .. in order to take pics of something very short lived.
Flew the Mini 2 ok the other day when I’d not noticed the cable had unplugged from my tablet.
I find that although the RC controller with the built-in screen is good it is possible to be looking at the aircraft and not noticing that a finger or the palm of your hand has pressed somewhere and logged me out of the program or done something I wasn’t expecting.
Normally the drone should either hang there or rth to its home point which is why I like to take off, rise to ten feet and wait until the drone has definitely established it’s home point.
Unfortunately the root cause of issue you experienced doesn’t appear to be signal related. Take a good review of the excellent RTH videos by MK Creator and if you’re using your phone as a screen, use a proper high quality cable … and be sure to read as much content as you can regarding disconnects and how to fly without it - then practice it somewhere safe - good luck.
@milkmanchris Many thanks for the various responses :+1:
I was using the cable that came with controller
… do you recommend replacing it?
… and if so, got a suggestion?
Cheers,
SteveC.
I’d check out the air data and try get a root cause in the first instance
If you’re not familiar with Airdata it’s an independent platform that allows you to aggregate your flight records and it also allows you to share logs with other people.
Here’s a guide on how to upload your flight logs to their web site / app:
Setting up Direct DJI Sync
Once your logs are visible in Airdata you can use this guide to share the log(s) in question:
Once you’ve created the share on the Airdata web site simply reply here and paste the URL, someone will then take a closer look for you.
The airdata shows the homepoint as being maybe 20 feet from where I launched the drone.
Drone went up vertically to 100m and then I got the RC alert.
Tried descending the drone, but no joy :frowning:
Also tried the RTH button, but also no joy :confused:
I’d not appreciated that I can still control the drone without a phone, and at the time I was still trying using the joysticks to get the drone to do something/anything, but nothing doing
I’m baffled as to how the RC can’t connect when the drone is 100m away in clear LoS, when I’ve happily had it at maybe 1km away over flat terrain ???
For my future knowledge… so the comms to drone is from the RC controller, and the phone is only acting as a display?
Until the drone has gone away from you by a horizontal distance (30m I think - might be less), RTH won’t function.
I guess in that scenario it’s a case of waiting for the battery to drop to the necessary level for the drone to land.
This is correct (in its most basic form)
The bummer was it started “drifting” away over the river, so i couldn’t follow it :frowning:
Shouldnt drift
Share the Airdata
Easy in hindsight .. but if it was drifting (strange that it was - they are very good at hovering in position) it would have reached a point where RTH would have worked.
But - still strange that you had no control from the RC, since a device is not needed.
What messages does the Airdata show? Sharing the link to it would help us see what really happened.
@milkmanchris I think I’ve got it …
Take a look at MK Creators RTH video - it needs to move horizontally too. RTH is complex technically and uses a mix of a ground image AND GPS - hence why going straight up doesn’t activate it
Looking at the airdat a few things jump out.
Not many sateliitles were locked, aim for high teens or low twenties.
Also I would suggest that connection was lost as you were not pointing the controller at the drone, it needs to be about 45 degrees in your hands and pointing at at the drone, you were straight up, very little distance from yourself. (probably holding the controller and phone flat in your hands, antennas pointing to the floor)
RTH would not work at such close distances.
