Quick question I was out today flying my Flywoo Firefly baby which comes in at a whopping 59g + 450g 3S battery when a guy started hassling me granted I was launching from what he quoted as his land to which I politely said that ok Ill go and sit in the boot of my car and carry on…
He then spouted a load of crap that I wasn’t aloud to fly over his building with out his consent. I pointed out the size of wot I was flying and explained im only flying round the carpark which he said is illegal and I would be arrested…
SO what are the rulings for FPV, are they the same as camera drones ??
And was I break any laws, after I moved and flew from the public road ??
You just need a spotter mate. If a landowner doesn’t want you there, go somewhere else.
You could waste a lot of time arguing the toss, but it’s not worth it. Just laugh and move on to the next spot.
Basically, yes. As Carl has stated, you also need a spotter to provide your VLOS but the rules about weights, registrations and where you can fly are the same.
This will fall into the whole debacle about how much airspace you need above your property in order to enjoy it. There is no real set height for this. With camera drones you’re generally quite high up and probably not photographing whatever is directly below anyway. With a tiny little 1S whoop, I’m guessing you’re probably a lot closer to the ground. Then there could be a difference depending on what “his land” is - are we talking about his garden or a bit of empty field miles from nowhere?
I’m guessing “450g 3S” is a typo. That’s a chonking great battery for the Firefly to lift. I suspect 45g is nearer the mark.
Think this was a typo Joe, Im sure he meant 45g battery.
Would be interesting watching a tiny 59g quad trying to lug around a 450g battery. Would need some serious thrust to weight ratio
