Landing My Drone - RTH or Manual?
Same here. Good to know it’s there for an emergency but generally speaking I would rather bring it back and land manually as often takes half the time. And I agree with @milkmanchris about the godawful noise!
We really could do with a 3rd arm, so you have two hands for the keyboard and one for the mouse :wink:
Drone has a camera, bring it in arse out
Evolution not needed, chimp brain here
Thinking about it, the ultimated would have been opposable thumbs on a prehensile tail as well! But of course if we had that, machines would be made that needed a fourth hand…
Ok, I’ll try that next time out if I remember; grounded for a week by the weather 4cast for a week or so now, and The Squeeze has banned me from flying indoors (the whirlywhizzy noise and the stuff blown about by the downwash freak her out).
Excellent advice and tips, thanks
Whilst being totally comfortable landing manually is a must, especially in gusts etc i do find myself using RTH quite a bit. After muting the annoying noise
I get a kick out of seeing my mini 4 ignore gps and apparently automatically home in on my landing pad. :wink:
I remember when I first got a drone. I went to a location that would mean changing post codes to crash it was so open. Had a lot of space around me. Played around and realised how easy it is to get back. Remember that if you feel a little concerned, take your hands off the control, take a moment and then just take your time till you get used to it. Bring the drone down slowling and then just make sure the ground is clear below and hold the stick down to make the final landing or press and hold the landing on the screen.
As @PingSpike said, we were all there once. You will find that the more you do it the confidence will build.
There will come a time when you will be telling someone on here that once you felt like this about your first flight…
Enjoy your flight. Let us all know how you get on.
Lots of great advice as usual here but since I’ve only been using a drone, mini 4 pro, for less than a year thought I’d chip in….
Mine initiates auto trh on battery low. It’s very conservative on this and has lots of power left after landing. I use the time to take in the surroundings and make sure nothings gone unnoticed while I’ve been flying. When it’s at about 12’ - and the camera still pointing down - I usually hit cancel and manually fly the last bit. I do that because at this height I can see exactly where it’s planning to land and quite often it’s slightly off the centre of my pad. Occasionally, when it looks spot on, I let it complete the auto rth but that’s less than 10%.
And I have the volume turned down all the time so the squawking’s actually reassuring!
I normally use RTH until its overhead, then bring it down manually. But then I am lazy !!
You should never be getting yourself into that situation. Simple as.
Agreed, and as I become less inexperienced (wouldn’t claim to be experienced yet) I’m getting better at predicting bad situations, but I got caught out week before last with sun glare; drone was only 50’ away but I couldn’t see a thing, and screen was difficult to see as well. If this sort of thing happens my default is to let it hover while I sort things out, but with the battery warning going off as well, and in clear airspace, I decided RTH was the best option!
I recommend you get a landing pad as that eliminates problems of long grass or dust being kicked up and helps with manual landings especially if its a bit windy. Good luck.
Yup,
Im in the habit of using a landing pad for a couple of reasons unless circumstances make it undesirable.
Dust n dirt. I like to keep things as pristine as possible so a pad helps with this.
Awareness. I find a pad helps random passers by realise I’m flying and trying to concentrate.
RTH landings. It gives the mini 4 something to home in on during a RTH. Since the homepoint can seem to drift somewhat, especially during long flights i find it useful. This works best if i fly straight up about 10ish meters on launch then fly off.
I can personally recommend the following.
Mine survived being forgotten on the roof of my car and subsequently spending about 90 minutes on a busy A road being driven over.
Just remember to pin it down, I have forgotten and the “prop wash” blows it away. :grinning_cat_with_smiling_eyes:
Check out the RTH comprehensive video by MK Creator on Youtube - an excellent reference for this important feature
If you’re staying close to your car, car mats do just as well and are heavier :wink:
I now use an old picnic table top with the landing pad Velcro’d to it, good for when ground uneven and sometimes I use a trolley to lug my gear (camping chair plus drones & picnic) I then pop the table on top of the trolley.
Not fussed on landing mats tbh. I can usually hand TOAL so I don’t think I need one, and on the odd occasion hand TOAL can’t be done tthere’s usually something clean & dry to set down on. My attitude to this is probably ‘informed’ by my not having a car, so flying trips are limited to walking distance or bus (I have a Welsh Assembly Goverment free bus pass).
So, bulk & weight need to be kept to a reasonable minimum, as do the number of items I carry. I know a landing pad weighs next to nowt and folds up pocket small, but then there are the pegs and their mallett. Which are u/s on hard ground or paved surfsces anyway! For that, you need to carry stones because you cant always rely on them being handy; more weight!
Not criticising pads, or people who use them, but for my situation they are more faff than I need! I can deffo see the attraction if the stuff just lives in your car boot, always to hand and no bother, though.
