Hay guys and girls does anyone know how to set up led lights on BF I have matek 2812 led strip slim RGB I have wired them up and been on BF all I get is a running red light coming on nothing else
Can you post a screenshot of the led tab?
All I get is a pulsating red light
You need to set it up, the YT video will show you how
I using different led mate I have led strips and I need to know why I’m only get red light
Sorry wrong video…
I see this yesterday I have done everything all I get is a red pulsating light they don’t change on BF
Do you have LED_STRIP function enabled in BF configurator?
What flight controller are you using?
Do both strips light up or just one?
Do you want to share your CLI ‘DUMP ALL’ file? then we can re-create it and see what is going on.
So yes I have the BF tab for the led the FC is the diatone mk1 easy f405 and as for the diff I can’t see how to upload files here can only take pictures
Just type diff in the cli, copy the text and paste here
diff all
version
Betaflight / STM32F405 (S405) 4.2.4 Oct 20 2020 / 08:18:45 (fbcaf8c50) MSP API: 1.43
config: manufacturer_id: DIAT, board_name: MAMBAF405US_I2C, version: 45b6e90d, date: 2020-11-27T19:02:33Z
start the command batch
batch start
reset configuration to default settings
defaults nosave
board_name MAMBAF405US_I2C
manufacturer_id DIAT
mcu_id 0028002c3256500920363752
signature
resources
resource MOTOR 1 C09
resource MOTOR 2 C08
resource MOTOR 3 A09
resource MOTOR 4 A08
feature
feature LED_STRIP
map
map TAER1234
serial
serial 3 0 115200 57600 0 115200
led
led 0 5,10::C:4
led 1 5,9::C:4
led 2 5,8::C:4
led 3 5,7::C:4
led 4 5,6::C:4
led 5 5,5::C:4
led 6 5,4::C:4
led 7 5,3::C:4
led 8 6,3::C:4
led 9 6,4::C:4
led 10 6,5::C:4
led 11 6,6::C:4
led 12 6,7::C:4
led 13 6,8::C:4
led 14 6,9::C:4
led 15 6,10::C:4
aux
aux 0 0 0 1925 2100 0 0
aux 1 1 2 1925 2100 0 0
aux 2 2 2 1400 1600 0 0
aux 3 13 4 1925 2100 0 0
aux 4 15 1 1300 1700 0 0
aux 5 39 3 1950 2100 0 0
master
set acc_calibration = 30,29,56,1
set min_check = 1000
set max_check = 2000
set dshot_idle_value = 700
set pid_process_denom = 2
set osd_warn_core_temp = OFF
set osd_warn_rc_smoothing = OFF
set osd_warn_fail_safe = OFF
set osd_warn_launch_control = OFF
set osd_warn_no_gps_rescue = OFF
set osd_warn_gps_rescue_disabled = OFF
set osd_vbat_pos = 2530
set osd_remaining_time_estimate_pos = 2100
set osd_flymode_pos = 2106
set osd_vtx_channel_pos = 2549
set osd_mah_drawn_pos = 2496
set osd_craft_name_pos = 2089
set osd_altitude_pos = 2081
set osd_warnings_pos = 2537
set enable_stick_arming = ON
set name = blessTX420
profile 0
profile 0
set throttle_boost = 7
profile 1
profile 2
restore original profile selection
profile 0
rateprofile 0
rateprofile 0
set roll_expo = 6
set pitch_expo = 6
set yaw_expo = 8
set roll_srate = 42
set pitch_srate = 42
set yaw_srate = 42
rateprofile 1
rateprofile 1
set roll_expo = 60
set pitch_expo = 60
set yaw_expo = 60
set roll_srate = 50
set pitch_srate = 50
set yaw_srate = 50
rateprofile 2
rateprofile 2
set roll_expo = 5
set pitch_expo = 5
set yaw_expo = 10
set roll_srate = 77
set pitch_srate = 77
set yaw_srate = 77
rateprofile 3
rateprofile 4
rateprofile 5
restore original rateprofile selection
rateprofile 0
save configuration
save
I’ll load this on my testboard tomorrow and see what I can find…
unless @notveryprettyboy gets to it first :laugh`
Enable led-strip in the config tab
Yep, if it was enabled it should show up in the featres section, but not there
Send us a DUMP ALL file to be sure
BUMP
Maybe. Sometimes its on by default and shows only if its off.
