That does make sense. The difference is quite jarring though. But I guess using a polariser doesn’t help. Thanks
Yup - the blue from the polariser would probably lend itself to an obvious manually added blue …. or just white … before uploading to Kuula.
It’s a great pic, though, that deserves to be seen properly in 360. I hope you upload. Don’t forget to post in the #panos category if you do … add to the Pano-Mania - (aka The Great Pano Thread) thread if you want.
That is much better
Going to cross post now
CRIKEY!
Full screen that’s so punchy!! Really good!
… and the ground detail means you really never look up and see the fill.
Gets you the Birds Eye Viewer Badge, too.
Yeah, I’m pretty impressed with this little* camera no tweaking was performed on this image, it’s all out of the camera.
*I’m used to a full-frame Nikon with hooning pro lenses on, but this blew me away, and will definitely have a place in my camera bag once I get the hang of piloting it and the confidence to launch it
Hi Nigel
I REALLY love that 360 pano. I’ve not tried to create one yet. Was it wasy on Kuula? Did you upload the raw pics - or the one created in ICE? I tried previously but gave up as I couldn’t work out how to get the size of the picture correct - plus how to add in sky etc…
The drone did it all. I did naaahhhhthing
I got nowhere with the individual images. I used Photoshop and lightroom but the horizon wandered all over the place. I looked to get my autopano giga in on the action but kolor seemed to disappear in October 2018 which is a bit of a git.
Indeed, @anon52324101, one distinct advantage of the M2P/M2Z is their ability to create a far higher res panorama stitch than our drones … and exposure control seems superior too.
Cool but what did you upload to kuula? Like 50 pics?
Why would you need to? As I just said, the M2P/M2Z create the hi-res stitched image. You just upload it.
The stiched image off the drone sraight off the SD card up to kuula.
Interesting… I tried a couple of these and I don’t think Litchi created a single file. Perhaps because it didn’t complete potentially. I stitched together as a simple Pano in ICE and got mixed results
This one is ok:
But this is weird:
Could be the perspective and angles I was using. The second one is of a round building and I was roofline (pretty much)
Can you do interactive Pano’s “around” a building? That would be cool!
Litchi doesn’t.
If you use the Go4 app with the M2P to create a 360 pano, it creates the stiched hi-res image on the SD Card. You can then just upload that to Kuula.
I think you can with kuula
Ooooo! I’m guessing that’s cool! (No data at Land’s End to view.) I’d been told otherwise.
Great news!
Its been in forever, it stitches a low res (like above) from cached images, or you can download the hi res from the MP then ask for a higher res image which you then share via the usual or upload to Kuula.
Mixed results as with all pano makers, if the light is right and subject has lots of reference points then they can look brilliant (the one above is one that just happens to be still in the app from May).
Ah! Just read properly. Like Go4 then … crap low res stitched image.
Knew you could stitch the images yourself.
The M2P/Z do it in hi res … but only Go4.
So I was correct … Litchi doesn’t stitch hi res.
I’m not sure why they bother with the low res. They really are crap.
