Mavic 3 Pro Cine - Intermittently very slow
Hi there,
I’ve recently bought a Mavic 3 Pro Cine and it’s been a real pleasure. I wanted to try out some tests on the advanced RTH method. The first couple of flights were spot on landing on top of the pad, the next flight was really strange, on powering up the done didn’t lift to a metre, stayed on the pad with the props tuning. It responded to the left stick but only lifted very slowly and horizontal flight was barely there. All of this in C mode, one point to add I have Drone Tweaks recently installed on the RC Pro.I was unable to test further as I had a phone call to take my wife to the doctor. Any ideas ?
Did you try it in N mode?
I didn’t as I had a call to drop everything as the Dr wanted to see my wife.
I’ve had this before on very very few occasions,
My thinking was if it wasn’t happy & was kinda detecting something / sensors ( I remember ) it acting this in mist / fog .
It was very clear conditions, I’m going to try again. Makes me nervous going over water
Please do & let us know how you get on .:))
Will do, I’ll record the video as well
You didn’t see any obstacle avoidance come up on the screen or any bleeping ? I’m guessing No .
No warnings, I have the settings in metres and I was getting around 3m/s in horizontal
I think the default is around 5ms ( I think )
Not something I’ve ever really played around with to be honest my cine is assigned to Atti mode :joy:
Isn’t there a setting in the controller / fly app that you can change the parameters :thinking: I’m sure there is so if it still does it id take a look, the settings are in there somewhere but I can’t remember where.
Edit : yes in the Gain and Expo Settings within the fly app .
I didn’t know this or was overlooked :down_arrow:
  • The Speed Limit: To comply with this safety standard legally and automatically, explicitly details that whenever the remote controller switch is flicked to Cine (C) mode while in the UK or EU, the firmware automatically locks the drone into this “Low Speed mode” profile. This caps your maximum horizontal flight speed at exactly 2.8 m/s, which your on-screen telemetry rounds up and displays as 3 m/s on your controller.
Can you bypass this?
Because it is a hard geo-lock based on your GPS location to keep the drone compliant with local laws, you cannot slide the setting back up to 5 m/s while flying in Cine mod
I’ll check the number again, but the fact it wouldn’t lift to a Metre and slow on the controls
My Air 3s or mini 4 pro aren’t locked into a slow mode in Cini? They behave as I set them up in the settings. :thinking:
Also. regardless of what mode you left it in when powering down, it will always default to Normal mode on start up.
It won’t stay in Cini. You have to switch it to normal, then back again to Cini to use its settings on power up. It’s the same if you left it in sport mode. Its a built in safety feature. However, having never bothered with using a software hack, or Fly app alternative, I don’t know if the feature still applies.
Same for both of mine as well. :+1:
Is it possible for you to do a controller screen recording? Yall has me curious :slight_smile:
