Mavic Mini and change of phone... Flight logs?
Hi,
I’ve just bought a second hand phone to use with my controller (and I’ve checked, it is compatible).
My question is, what happens to my current flight logs, total reported flight hours/distance etc when I start using the 2nd phone, or is all that stuff sync’d from my DJI account?
Cheers,
Ned
If you sync’d your flight logs up to DJI then you can pull them back down again on any device.
Or use someone independent like AirData :slight_smile:
Perfect! Thank you
