Mini 4 Pro / RID
I have a DJI mini 4 pro. At the end of next year it’s going to be an expensive ineffective plastic paper weight. I have no intention of paying to go through the A2 CofC rigmarole as I only fly the drone sporadically but enjoy doing so on such occasions.
Come 1/1/2028 the thing has to transmit RID. It has the capability of doing so now but only if plus batteries are used putting it over 250g. Why? This is a con. Is there any way the firmware can be accessed to enable RID transmission with standard batteries? Why should it only be available with plus batteries when the coding is already on-board?
This is part of the ongoing war against drones, just like the relentless war against cars. AI has been used to hack most cameras to extend their capabilities beyond what the manufactures intended. Are there any AI people out there who can do the same for DJI drones?
If nothing else, I’ve got that rant out of my system.
You don’t need the A2 CofC on the Mini 4pro and it will not become a paper weight - why do you think it will be ?
If it has a UK1 or UK0 class mark on it - ( it will be a UK0 on standard battery but the rules are UK0=UK1 so no big deal here ) if its a C0 drone ( more than likely ) it will just become a legacy sub 250g drone and you will still have the same UK1/UK0 Freedoms - if you have a larger drone like an Air 2 etc then yeah the rules get a bit crazy
As for RID - that will become enabled as part of a firmware as its already on that drone in the USA and I beleive in Europe so its just a geo lock for now
Just remember that the RID and the class etc is a part of the conformity of the drone - its not linked to weight but a lot of other aspects
So don’t get too hung up on things just yet - closer to the end of 2027 I expect there will be some rule changes ( I hope ) as there is such a mess with drones like the Air 3s and others that some have just EU marks on them and others bought just a day or so later that have both UK and EU marks on them - the CAA really just needs to extend the C class = UK class thing indefinitely and say all drones need RID - so lets hope that will be the case and you need not worry about anything.
Thanks LE60LAD for your reply but I am confused. The drone does have a C0 label as you suspect, sorry for omitting that info. As I understand the situation mini4 pros do transmit RID when plus batteries are used but plus batteries take the take-off weight of the drone over 250g therefore removing it from the C0 category. Are you suggesting, when the time comes (1/1/28), the mini4 pro will transmit RID on standard batteries and therefore remain in the equivalent C0 category?
Yes when it comes to 2028 as per the requirements by the CAA C0 drones and other C class drones will need to transmit a RID - so for now its not an issue so its not enabled by DJI - as to why it does come one when you put a plus battery in I can only suspect that DJI made a bit of a boo boo as it becomes a UK1 drone then and not a C1 drone as UK1 drones now need to have RID as of the start of this year - so my Avata 360 has that option available to it ( as does my Air 3s that only has a C1 on it and not a UK1 - hens my comment about what the CAA need to do come 2028 with the C class being carried on )
So as per the rules of the land ( the CAA ) C0 and any C class drone do not need RID till 1/1/2028 - but UK1 do from 1/1/2026 - ( so I guess someone made a boo boo at DJI on that rule when a plus batter goes into a C class drone )
Don’t get too hung up on the weight thing as its not just weight that governs the class of a drone any more - its weight - sound - speed - hight - how it’s made - how it breaks up and how the software behaves etc etc - its a sum of all the parts that make a drone C class or not - its a conformity standard
Okay, thanks for that. We’ll have to see what happens between now and the end of 2027. If RID is transmitted by the drone as it stands with standard batteries then there’s no problem. At least I’ll still be able to fly, legally, if only intermittently.
I am sure it will be when it comes to the regs needing it in 2028 - it already does it in other countries so it has to be a geo lock thing and for now as there is no need for it, its just not there - I do think they should just put it there and if people want to put in the RID then it will work as it should before the due date I see no hard and then it will eliminate confusion such as this has done so already.
I no longer have my Mini 4 Pro, and I used it with both standard and extended batteries. However l am pretty sure it was already set up to broadcast RID data. The setting was under Safety in the Fly app, just above the Find my Drone item. If the drone and controller software are both up to date you should be able to set up RID.
Just had a look on mine and although it is there I haven’t the license to enable it. Everything is up to date.
Alan
Are you seriously trying to tell us that you are flying a drone without an Operator ID ???
No? I was referring to the ability to enable RID
Alan
As far as I am aware, if your software is up to date, you already have the ability to broadcast RID. The actual code you need to enter into the software is derived from your CAA Operator ID, and you can find it on the CAA website.
Think I will concentrate on trying to fly it first!
Alan
