Mini 4 Pro spare props availability
Good afternoon, I am trying to source some spare props for my Mini 4 pro and it seems that they are out of stock with DJi in the UK and on their .com site. Are any of the alternatives any good , as I am loath to risk using copies as , although they seem a simple enough bit of plastic, I imagine DJi have spent a great deal of time perfecting the design ? Any suggestions would be appreciated. If the manufacturer can’t supply them then a drone might become unuseable.
The most common scenario where you need new props is a crash, in which case you typically need more than just props. Hold out for OEM props so you don’t void your warranty/Care Refresh.
Indeed. Sadly , following DJi’s technical support I was told to turn off advanced avoidance to replicate an issue I have, the drone became unstable and flew into some curtains, causing 2 props to be slightly damaged, so I have had to replace 2 pairs from my spares and am now running low.
Try Master Airscrew ones - I’ve had them on my Air 2 and Mini 2 for years
E.g Amazon.co.uk
Thanks for that info. It seem that mini 3 props are the same but use different screws, so I have just taken delivery of 3 sets and will use the Mini 4 screws with a dab of blue Loctite, which seems to be a solution. I wonder whether the different screws for the 3 and 4 are down to weight saving ??
Google says :backhand_index_pointing_down:t2:
The DJl Mini 3 and Mini 4
Pro (alongside the Mini 3
Pro) use slightly different propeller screws because of minor design variations
in the motor shafts and vendor/manufacturing updates.
