Mini 4 Pro - Using Propeller Guards
Hi All
If you have a mini 4 pro do you have any concerns about using the propellor guard ?
It may be me but I feel when clipped together it looks like its bending and putting a strain on the props and motors.
I originally thought the same, but upon further investigation (a quick slight turn of the motor bell) it was clear that there is no pressure on the props at all as they just sit nicely in the pre moulded gap in the gaurd. obviously only if you’ve installed it correctly that is. :+1:t2:
Thank Deano for the reply much appreciated.
