Just updated the software, App version 1.21.16, AC firmware 01.00.1100, RC firmware 10.00 0900 and am unable to land the drone. Obstacle avoidance is set to OFF but is still showing as active and prevents landing. Only way to get the thing down is to turn off the RC and restart it, the drone then lands. Anyone got any clues about this ?? It seems a bizarre situation and I have replicated it 3 times. Thanks for any insights .
Can you tell us what happens when you try?
With obstacle avoid set to off on the RC, but still active on the screen , the drone just will not land untill the RC is switched off and back on . It then seems to auto land once the check box is confirmed as being safe to do so.
I take it you’re trying to land manually using the sticks?
Are there any messages appearing on screen at the time? ![]()
Yes, manually , as I have always done. The screen shows the red ellipse indicating Ob Avoid is on, respite it being off on the RC settings. I have tried landing in Sport mode where Ob Avoid should be disabled, but it isn’t !!!
Is it at the bottom of the screen?
Is that the drone telling you there’s an obstacle in the way and it won’t land because of that red ellipse?
ie. it thinks there’s something in the way, even if there’s actually not?
Does it only appear when you get down to a certain height above the ground? Or is it there for the duration of your flight no matter your height?
It is detecting the ground below and will not land, it only appears when I try to land it. there is a 0.5 metre text at the botom of the screen in RED
Sorry if therms seems like a silly question or the obvious, when trying to land manually how long have you tried holding the stick down for it to land ? Does it look likes it’s hesitating to land ?
Well I wondered that and held it down for 15 seconds, it isn’t hesitating, just refusing !!! Just spoke to DJi support who couldn’t suggest a solution apart from using the screen " take off " button to land the thing , which worked once a check box had been checked. So, I can land it automatically but not manually, which isn’t right. They suggested I try it outside as the surface I was trying to land on might be an issue, carpet which has never been a problem and the same issue appeared when landing on matte black board, so no progress there !! It’s abit stormy outside at the mo, so that is going to have to wait. In fairness, the DJifellow was trying to be helpfud and suggested , maybe, I return it to them for diagnosis…
That was going to be my next question have you tried in a different spot .
Tell me about it, anyone would think the Exorcist is in my house the internal doors are shaking ![]()
Good luck with your findings hope you get it sorted ![]()
I will report back in due course and thanks to you and PingSpike for the input. Maybe your avatar is trying attract your attention !!!
If we assume it was working properly before you upgraded, then its logical to assume some part of the upgrade blew it up.
So…is it possible to redo the upgrade - controller, then try it, then drone, then try it - and see which package blew it up
Regardless, keen to see how this gets resolved - good luck​![]()
@notnowcato, it would be really useful if you could share the Airdata logs for this issue, it’ll help people provide you with a more detailed answer based on what actually happened.
If you’re not familiar with Airdata it’s an independent platform that allows you to aggregate your flight records and it also allows you to share logs with other people.
Here’s a guide on how to upload your flight logs to their web site / app:
Setting up Direct DJI Sync
Once your logs are visible in Airdata you can use this guide to share the log(s) in question:
Once you’ve created the share on the Airdata web site simply reply here and paste the URL, someone will then take a closer look for you.
What height does it register if you fly through a doorway ?
I just wondered if it was a calibration issue. That’s all I’ve got. Best of luck.
Hi, I have used it so will see what can be done. Thanks for the suggestion. Previously , with obstacle avoidance on , it would not land until I switched it of as I was about to land it. Now it seems to be constantly active . I am going to wait until a more gentle day and have a proper fly about.
April 17th is booked in as a more gentle day. ![]()
Have you tried updating the firmware, both on the drone and the RC controller. I’ve had issues when trying to land, both palm landing and ground landing, where it’s hesitated and takes a while before it decides to land. Again, no clue why, I just thought it was my flying​![]()
This issue seems to be a result of doing just that, ascmentioned in the first part of the post…
Users on the DJI forum are reporting that there is a 1.21.18 version of Fly available.
