My Drone went for a swim
Yep a silly mistake, I thought I go slowly dodging overhanging trees only 2 mins into flight I thought the Obstacle avoidance will save and bypass but instantly hit a leafy branch and went blank, strange it cutout hitting tree not when hit water
I went down to river walked up the stream took about few about a minute to locate sitting nicely like it landed under foot of water, instantly removed battery
Phoned the wifey as she was in town bring bags of rice home, think she thought she was in for a treat me cooking :joy::joy::joy:
After googling it seemed rice was not the best idea, I first blew it out with air gun then a hairdryer for 20 mins while had empty tumble dryer on full heat, I then placed the drone in stopped dryer for a hour and use hairdryer agsin and second time tumble dryer, turn on the radiator on ½ boost last night and again this morning.
I read wait a few days or a week best before knowing to get a replacement, I have no patience for that as I’ve stripped drones a few times I knew that after what I did should have dried it out.
Turned on it went thru the process but red and white light stayed on, so did a reconnect and screen came up but a load of errors, thought the gimble fuffed, did imu and errors cleared after bootup except one power system hardware error which I thought it’s definitely is buggered it advised reboot up and all clear and no errors, did a compass calibration as a precaution. Cleaned all the avoidance and gimble lens with the lens tool.
Took of a flew perfectly :grin:
Home point was off a few feet which unusual so did a couple of manual Home points and made sure it was aircraft, and now seems to be precision landing :grin:
Lucky as the river was crystal clear as there been no rain for a while otherwise it be brown and dirty from the hills, not being salty sea water was another saviour as it would have needed a soapy wash and more fear of corrosion.
I have care refresh, should I still use it even though all looks good ?
Care refresh would still cost you. If it works to your satisfaction I would carry on.
If it had been salt water you would now have a load of mush.
Never buy a car from West Mersea, the idiots drive through 2 feet of salt water when the tide is up over The Strood.
I’ve been flying 10 years and never had any problems with water but in a space of 2 days I’ve crashed 2 drones into a river and stream :flushed_face::flushed_face::flushed_face::flushed_face::flushed_face::flushed_face:
Other day it was the mini 4 pro today it was the Neo :face_with_peeking_eye:
Unlike the mini 4 pro I spent about 40 mins from air compressor to hair dryer to putting it in the dryer before turning on again because it more sealed then other drones.
It booted up ok no errors and took off but then seen screen blurry the lens got all misted up, thought it was not cleaned on the outside but then I could see it was hazy inside lens, got the hairdryer blasting on the lens for a while, back to the monitor and ¾ of lens ok but flyable, about 4 mins into flight perfect vision all cleared flying perfectly. :+1:
What’s next :flushed_face:
They say things go in three’s :grimacing:
Or hopefully third time lucky :crossed_fingers:
