I’ve now been flying drones religiously for about a year now. It is mostly FPV, some camera drone stuff (Mini 3 Pro). Sim and regular stick time have given me the basic chops to fly FPV confidently and crash not as often as I was in the beginning. However there is a tendency I have to avoid difficult moves now, to prevent crashes and losing props. I know I need to dare more to progress.
Out of the FPV drones I have, I enjoy flying my Air 65 II whoop and Rate W20 (2" open prop) the most. The Rate has great power while the low latency of the Air 65 II is sublime. Analog box goggles (Eachine) aren’t great, but I’ll address that in the future. I also fly with DJI Googles N3.
I’d like to move a step up in terms of power and size, gain more efficiency and flight time. Preferably with O4 modules at this stage. Analog is fun, but will probably more for close range and garden or park flights. I only have 1S and 2S chargers at this point.
I have a spare O4 Air module as a result of my recent DJI Support shenanigans. I also have got a Rate Wide Angle conversion lens, plus CNC casing, which I’d like to use to keep the O4 protected and cooler. Controllerwise I can fly DJI FPV Controller or ELRS (RM Pocket), which gives me flexibility. The drone kits I have on my shortlist are (in now particular order):
Deep Space Seeker 3
Deep Space Seeker 35
Rate S30 (3")
Rate L40 (4", weird size?)
Deep Space Seeker 5
I am not planning to purchase the drone with a prefitted VTX. I want to use my spare O4 Air instead.
I am leaning towards 5 inch, as I would like to fly with an Osmo Action 4 onboard, on occasion, hence why the video quality of a O4 Air is not a priority. In terms of flight style, I am probably more like “cinematic with a bit of freestyle” corner. I also like putting down some cones on our playing fields and do a bit of racing every now and then. But whether I use a 5" for that is another question. Probably not.
My DIY and soldering levels are “beginner”, I’d say. Therefore, a RTF or a setup with little work required is preferrable.
Which drones should I consider in these size categories?
When I first started out with proper FPV, everyone told me to start with a 5”, however I started with a 3”, my thought process being, it’s lighter and will have less inertia, so I believed it would cause less damage when I crashed it.
However my thought process was wrong and I trashed it on its maiden flight.
I do find the 5” more thrilling to fly, with it being 6S it has the power to pull out of moves / tricks that haven’t gone as planned.
I’ve heard good reviews and thoughts about the Speedybee Mario Mini series of quads, which have interchangeable heads, so you can switch one VTX between the various models in that range.
Some good options there - those BNF are amazing value. They are by no means “bando weapons” but will cope well with crashes on soft ground.
For size - it really depends on where you can manage to fly.
The bigger the prop/weight - the more space you need to enjoy flying around. Also - the more you progress as a pilot, the less space you need
As a rule of thumb - think of the smallest flight area you would need to have fun with your Rate 20.
To enjoy a good 3inch drone the same way (double the prop area) - you will likely need to an area 4 times the size (double each boundary)
To enjoy a 5inch - you need to do the same again…
4inch props are less common so less choice
If you want to carry an Osmo - then as you said - 5inch is the min size where it will not destroy the flight perf (I would argue you need a 7inch )
I live in a very rural spot, therefore my flying is mainly around the fields in our area. The Rate W20 I fly around our Village Playing Fields, which is approx. 150mx150m. A lot of remote fields here are 3-4 time bigger than that. You got me thinking of going for a 3" instead. Since I enjoy my 2" Rate so much, I can imagine to get similar fun from a Rate S30, which gets good reviews and is compared to the Seeker 3 a lot. Another advantage is that the S30 is <250g. I need to check if my wide angle adapter for the Air camera fits on the S30. Rate’s AI support chat seems to suggest that the adapter doesn’t work, but I wasn’t too convinced.
I’ve got a choice of ELRS and SBUS. I prefer the DJI controller. Does ELSR give me bigger range? And does this matter, because if I lose video signal then a connected controller won’t help me much.
What does your cam look like now? Flywoo shipped their wide angle with an “O4 Pro frame adapter” – I have a few of those happy to let you have one.
Looks like the back casing of this pic
As for ELRS/DJI controller - range/penetration is not massively different (there is a hard limit on DJI range - but way past VLOS )
The big advantage of ELRS is the access to tons of radios - with potentially more switches, better ergonomic, bigger gimbals,.. but if you hare happy with the DJI controller already
Incidentally, I already have the Flywoo adapter, which I used on my old, broken Meteor 75. I made a hash of it when I detached the standard lens from the image sensor. Therefore, I am not sure whether I’d like to use it again. But this is another option.
Thank you for the offer, by the way!
Update: hang on… this is something different, isn’t it? Mine is the standard cam of the O4 Air module.
Ok, got it. I’ve got a spare Flywoo O4 Wide Lens Set, which is the DIY option. I think I’ll give the Rate Wide Angle Conversion kit I have a go first. It was a fairly inexpensive option and included the CNC cover.
When using the DJI control system, if you lose video reception you also lose control reception too, so the drone fail safes (and crashes, if you don’t have GPS rescue set up), however an ELRS receiver and radio, will continue to communicate, so you still some control your quad, even without video.
The ELRS system will have more range and penetration than the DJI system, it’s more versatile and can be used with both digital and analog systems (including DJI, Walksnail, etc…)
I seem to recall, that someone on the forum was selling an hardly used Radiomaster TX15, but for the life of me, I can’t recall who it was.
@Steviegeek - who was it that had the TX15 for sale?
Thank you! I’m ok with my RM Pocket, which I bought for my first, minimal analog setup for the Air 65 II. I probably prefer the feel of the DJI Controller at this point, although I appreciate going down the ELRS route gives me more options and functions down the line.
I’m a bit more settled on a 3” now. It feels like a good next step up. I’ve narrowed it down to the Rate S30 and the Seeker35, as the non-VTX, PNP versions seem reasonable. I’m going to have to factor in 4S or 6S batteries, plus a charger, though.
Ok, I’ve just pulled the trigger on a DeepSpace Seeker 3”. I had to get batteries, a charger and a charging adapter too. I bought the non-VTX version, because I’m going to fit a spare O4 Air Lite with a Rate wide-angle adapter on it. I went for a Hots T6 charger, which I can extend in the future if I want to. But it’s single battery charging to begin with. I went for 850 mAh 4S to stay just below 250g but give me a fighting chance of 8 minutes cruising.
