got a copy of the Litchi Beta so I could try out and see how it compared… i would fly a bit with the MA1 then try the same thing on the mini… all works really well and features like follow me and track are good…
But the note to self… when testing a feature make sure the drone has it…
Result = Building 1 - MM 0
Testing to see if the obstacle avoidance works would have worked better if the MM had obstacle avoidance
Lucky only a few scratches to the body and some broken props
If you go to your profile, and scroll down and click on “Title”, you can select the badge to make it appear after your username in posts … as you’ll see some others’ do, above.
