The youngun went paddle boarding so got some of my first over water shots.
Slight panic as the phone ran out of power whilst over water, but was able to fly back as the controller was still connected etc ( dont you just love line of sight! ).
Near to Bradford airport ( ish ) so 60m ceiling, but it all worked very well
Totally :-), I was very careful re RTP at the start, so the button / 25% battery would have triggered it all nicely. It took a minute or so to realize that it wasn’t coming home when the screen died, but then noticed the controls where still working.
I’ve noticed the control unit powers my phone. Not sure how your phone died but the controller still worked Hope it doesn’t happen to me. My line of sight is about 30m before that tiny grey thing disappears
I have a tiny strobe velcroed on the bottom of mine that helps massively ( sunlight and direction of drone dependent of course ).
Phone died due to daftness on my part, I didnt charge enough and the power from the controller coming in was less than the power needed to run the phone in bright light. Took off on about 15% power on phone and two flights of 20+ mins later the phone powered down But controller still had link, so no real bother and if I had been out of sight or panicked, I could have used the RTH button. I guess its a good thing to learn, do the take off checklist, fly sensibly and dont panic if things go wrong ( with a GPS UAV ) and know / trust your ability and kit.
Not sure on the power output capability from the controller to the phone, I think its not enough ( cable issue possibly ) to increase phones battery, just keep it in check, maybe due to screen brightness, signal strength, WiFi being on / searching , GPS etc ? I will check on fully charged phone next time to see if I can stick at 100% or if it drops a few notches.
Unless I have completely misunderstood, according to demos on YouTube, the Mini 2 would have returned to home position (last logged Home pos.) even if both the controller and phone malfunctioned.
If I am wrong on this one, can someone enlighten me
I think it depends on the device and the power demands of that device whilst using the DJI app and other background tasks.
I use a 5 year old Android that’s a dedicated drone-phone, with almost nothing else installed and always in airplane mode when flying.
It manages to charge this whilst in use OK. Not rapidly, but sustainably.
I’ve often wondered if a Y cable could be used such that RC and device and both be being charged from a power-bank whilst in use, but since my RC/phone last longer than my 5 MP batteries, and recharge faster than my 5 MP batteries, I’ve never had the frustration levels needed to investigate.
Yes indeed, if the controller looses connection it will return to home ( if set etc ).
My issue was the phone screen died, so controller was still connected to the drone and it was still happily thinking it was under control, I just wasn’t able to see the cameras view.
It took a few seconds to remember this, but then I was able to fly home ( or I could have pressed the RTH button to get it to do this )
Everything other than the pilot did as it was supposed to do!
Christopher the photos are great especially the pano
I use a Galaxy Note 8 on my DJI controller so not the newest of phones and I find that the phone saps more power than the controller puts into it, I also thought about using my old Sony Xperia as a dedicated controller screen but put the idea out of my head when I thought about the updates and all features on the DJI fly app… do they not need phone signal to operate properly?
Cheers, I’ve even thought about installing the fly app on the wife’s phone as a back up but thanks to you guys she is completely redundant now and has no need to be there
Yup this was all set, it was just a scary moment when the screen died. It took a few seconds to realize the drone was still flying and that the controls still worked
But yes I could have RTHed or let the drone come home when the battery started to deplete.
The one learn I had with this was that, Line of Sight is very important ( along with knowing position, and direction etc ) and not to panic, but to think through things when something goes wrong like this.
Good learning, especially at the mo with the iffy DJI Android code thats out ( had a software / App crash last night ( had this a few times now, I was able to restart the App and it connected to the drone after a few seconds ).
