Peebles 2025 with snow
Do you use the pro version of Kuula? When Iā€™ve tried to do a 360 it only will upload 25 images, (my drone takes 26), if I miss one out it doesnā€™t look right. I tried the free version, not paying Ā£20/ month for pro, itā€™s extortionate.
i have the mini 4 pro that has the 360 pano function, and the drone combines it into one photo, so all i have to do is upload the stiched version that the drone has made, when i had the mini 2 their is a peice of software by dji that stiches the mini 2 shots to make 1 pic. Think its called dji media maker. The updates for this software is discontinued DJI Media Maker - Download Center - DJI
this might help https://www.youtube.com/watch?v=oVeqRYvhCLE
The mini 2 also produces the ready stitched image for upload to Kuula
I was replying to Seadog who posted this ā€œDo you use the pro version of Kuula? When Iā€™ve tried to do a 360 it only will upload 25 images, (my drone takes 26), if I miss one out it doesnā€™t look right. I tried the free version, not paying Ā£20/ month for pro, itā€™s extortionate.ā€ it has been a long time since i used a mini 2, just attempting to help
Thanks for that Iā€™ll have a look. Yes my M2P does but canā€™t fly it round here. On the prom Iā€™m using my mini 2 se.
For clarity Phil, Kuula does not stich the images you must either use the onboard file your drone makes or use alternate methods (AutoGiga Pano AGP is a great free tool for this, and well discussed on here)
The 25 image upload you speak of is 25 of the ā€˜stitched imagesā€™ at any one time, up to a maximum of 100 in any month on the free plan
Iā€™m confused! When I take a 360 pano with the mini 2 se it takes 26 jpg images and puts them a unique folder. But they are individual images not stitched. It was suggested I upload to kuala to stitch them into 360 pano. The first time I tried this it did so but only would accept 25, I had to miss one out. It did the job but there was a kinda swirl compared to others Iā€™ve seen. When I tried this morning I couldnā€™t get it to do anything like a decent job, more like an extended 180 with a tail.
I have affinity photo 2 which does a good job of 180 but not 360.
Which you can stitch manually however
While the drone is on look in the album / media tab and you will see a stitched image (the fly app has done this and not the drone like on higher models)
Download this file to your device and then upload that to Kuula
Should like this
Ah! Cheers, Iā€™ll try that, thank you.
