Random disconnect Air 2
Morning, had a strange disconnect on my old Air2. Was on the field near me only at a height of around 15 ft when suddenly the remote disconnected, the drone performed the RTH but didn’t return at the height set just stayed at the same 15ft elevation. Prior to it disconnecting I heard, then spotted the Air ambulance helicopter it was quite close proximity to the field hence the low height of the drone but it was just as the copter was starting to pass that the disconnect happened so was wondering if it was just a coincidence, interference or some sort of anti drone system the helicopter was using lol never happened before
That’s right, it won’t move up or down to your set altitude until it’s much further away from you.
Thankfully not :slight_smile:
Thanks, knew I was probably overthinking it and more of a coincidence but you never know these days :smile:
Share the Airdata
