I’m looking for a decent RAW processing option for the DNGs from my Mini 4 Pro. I like On 1 (I know it is generally hated, but I think it is neat) but that doesn’t seem to have a camera profile for the drone, and neither does it seem to use any embedded profile in the files, if there is any? The base image has a heavy vignette. Although I can correct this by eye, that isn’t really sufficient for using the files for panoramas where there will inevitably be banding.
The familiar open source options seem to use the same Lensfun database (which hasn’t been updated in years) and have the same problem with the files.
Are there any free or paid options which handle the Mini 4 Pro files well? I would only be processing about a dozen files a year so would find an Adobe subscription somewhat prohibitive for my requirements, but an app with a perpetual licence for under £150 would be in budget. Mac ideally, as my macbook has my best screen, but I also have Windows and Linux devices.
Have you looked at RAWTherapee. No idea about specific profiles within it, though.
Yes, it uses lensfun too, unfortunately. All the open source options use it, I think.
I don’t know it well .. beyond using it as a (very slow) plugin for Hugin panorama stitcher.
Ah, thanks. I don’t think I have a device with a large screen which can run that, unfortunately.
I don’t think Snapseed removes vignettes, from what I’ve been Googling? Forgive me if this has been added.
I think the way forward may be with DXO. I’ve tried the trial version of PhotoLab and it does a good job of lens correction and fairly decent vignette removal, and the noise-removal and sharpening seems excellent. I don’t really like their colour tools, though.
I think the way forward is with DXO PureRAW then direct export to On1 after lens/vignette/noise correction. It is fairy pricey to act as a filter, but I can probably hold off to see if there are any Black Friday deals. Open to other suggestions in the meantime! Thanks all.
How did you add it in the first place?
I think that’s for adding a vignette?
That’s just what the unprocessed raw files produce. It is very pronounced on the Mini4Pro raw files
Unfortunately none of the apps which use lensfun work at all. It hasn’t been updated for years. It has profiles for things like the Phantom 3 but no modern DJI drones.
Try the 3582, its the Mini 3 Pro (quite modern)
Here’s an example with the vignetting and lens distortion removed by DXO
