RC Pro Controller and DJI RC/ RC 2 with FCC hack by Sincoder
anybody seen sincoder, seems to have disappeared.
is the only option to use DH now?
He’s been dormant for ages I believe ….
I just had a look in the software pack (link posted above) and saw an alternative telegram contact: in the readme file
last seen ~ 2 hours ago…?
If you’ve had the mod previous from sincoder what you’ve just posted above their link works ( without ) having to purchase the key again apparently it’s all on the same server, I tested it the other month as ā€œ curiosity killed the cat ā€œ :grin: but it worked fine for me on my RC Pro, if you run the adb, exe file before you do any updates just to make sure it’s up & running & it connects, that’s what I was told to do by the guy at the link you posted above & all was good :+1:
That page hasn’t been updated since April
Remember to check the firmware version
DJI RC 1 01.03.1400
:x: The initial FCC installation is not available. Available for RC with firmware 01.03.1200 or lower.
:white_check_mark: If the hack is already installed and firmware 01.03.0400 or higher, you can update RC and run djifcc.exe again.
If the firmware is 01.03.0100 or lower, be sure to install the hack again before updating!
That’s why I contacted them as I see like you say nothing has been updated :+1:
I put the fcc hack on my dji RC controller which I was using for my mini 3 pro.
I now have a new (second hand/ new to me) DJI RC Pro controller … hence I was hoping to get another key as its not been registered it seems by the previous user.
DJI RC Pro with firmware version V03.02.0400 is what its currently got listed.
I was hoping to use the DJI RC Pro for the mini 3 pro + new mavic 3 pro I’ve got along with litchi… hence the reason for the RC Pro as I got fed up with two controllers.
DJI RC FCC | Dji Rc Fcc
Lets know how you get on
sent a telegram message, will let you know what happens via this thread (asked what happened to sincoder too). not too keen on usdt or other fangled crypto (hey ho)
So for RC2 what is the latest firmware suported by the patch if you have it already? Still trying to look all over the internet a out this and I can’t find an answer. Now I have 02.02.0200 and is patched.
I can report back that yes the djifcc hack still works and the telegram link above does work.
the person at the other end is not very communicative to say the least, and it was a bit like pulling teeth… one at a time…
i.e.
Q: are you still able to provide the djifcc key
R: hi yes I can do it, dji fly will be 1.13.10
Q: how do you want paying? does the original djifcc.exe file still work?
R: I think the same
Q: how do I buy the key?
R: paypal or crypto
Q: paypal
R: 73 usd
Q: where do you want paying to?
R: link provided…
Q: paid moments ago, thanks
R: wait
R: ok
R: software provided + key + instructions…
All worked good in the end, just needed to get my head into doing it again (did it with the RC originally). Also costs a bit more than directly via sincoder, but it works better than drone hacks (in my opinion) for turning off leds and other adjustments etc.
Hi all - any help pointers with this appreciated.
I’m returning to quadcopters after some ill health. I have charged up my Mini Pro 3 and I have been reading up what I can on here to try and catchup - it all moves quite quickly!
Firstly, by controller and quad firmware:
I remember before that it was advised to be careful updating firmware because it could break things and also cause problems?
That leads me onto my next question. I previously paid ā€˜dji fcc’ (Sincoder?) via Telegram for FCC mod etc. Although it worked well, it doesn’t look like he’s around any longer. I still have the pass key he gave me previously, but his link to the file (dji-fcc.com/djifcc.zip) doesn’t work any longer. Should I just carry on as I am with the existing mod and firmware, or should I look at updating everything? I’m still trying to find out whether there has been any advancements in either firmware or mods..
Any help or advise with the above would be very much appreciated. I have been reading where I can, but the nogging isn’t quite what it used to be - but I’m getting there..
Thank you.
Hmm, so replying to my own post, it seems I can update all firmware to the latest (mini 3 pro) for both the quadcopter and the controller and use Drone-Hacks V2 for everything.
Does that look right?
Check out
Put in the latest firmware in the checker to see
And our members get a discount
DH discount
Perfect, thank you. Love the idea of permanent solutions..
Hello everyone, any info/update about dji mini 3 + latest fw rc ?? sincoder alternative?
Hey
We are in the same boat, everything is working just fine but it’s always nice to have the latest firmware and offcourse :slight_smile:
So rightnow I’m stuck at
RC pro firmware 03.02.0900
Aircraft firmware 01.00.1500
Appversion is 1.13.10
When I update the App version the FCC hack no longer works
Any advice here or should I just stay on what I have ?
