It is you that is wrong here. The majority of others have no problem. You have a problem somewhere, either your hardware, your windows install or maybe even your cable.
You shouldn’t be rude to Sincoder telling him where to go he is a good guy and helpful. Maybe your rudeness has got his back up so he’s not keen to help you now
The reason that the file is flagged up as a virus by many scanners is because the exe is encrypted to protect the author losing his secrets, and that it connects to a remote server. All the signs of malicious software but in this case probably not.
As I said in earlier posts if you are worried reformat your computer after isi g the software.
Since when when was the Rc pro £250 !, and since you were not privy to Sincoders attitude then ill say what i feel is necessary to get my point across .If some is so clever to write code for a hack then why would they not bother to check it for malware ect .
My cable ? what are you on about i never got as far as that and i can asure you my pc was ok no hardware or software issues , and as for installing a virtual drive .
If anyone on here wants the hack then i will send it to them inluding the pasword which is needed , i have 2 one from sincoder and another i got from Rinzler who is a re seller .For now ill give it a miss and after talking to a more clued up person than myself he recons that the only time this malware could effect the rc pro is when its connected to wi-fi say you were downloading 3rd party app ect and not effect it during normal flying condition with no wi-fi or 4/5g connection.
RC Pro is compatible with mini 3 yes. See below for confirmation
I was considering upgrading to RC pro when Sincoder disappeared of the face of the earth due to the Drone-Hacks patch being available for it. Would have been very expensive exercise though
All good no worries ! Just decided to buy it from @djifcc on Telegram.
He gave me a pass, however, I get this error whenever I try to patch my RC, anybody has gotten the same problem ?
It Looks like Sincoder has gone a little further with his hacks
Full list of currently available commands from @djifcc Only works with patched DJI RC and RC Pro remotes (we will add)
gps on/off - enable/disable drone gps rcgps on/off - enable rc gps or not vps on/off - turn on/off all vison sensors led on/off - turn on/off drone led vled on/off - enable led on/off when record (set led on first) atti on/off - turn on/off atti mode manu on/off - turn on/off manual mode (be carefull) droneid on/off - turn on/off droneid (need drone firmware support turn off droneid) 5.8 on/off - enable/disable force 5.8GHz ,disable 2.4G CC US/CN/JP/RU/HK… - set drone country code (can disable FCC mode) force_fcc on/off - enable/disable force fcc (drone will ignore country code setting) disable - turn off all hacks enable - turn on all hacks reset - reset to default config
As soon as you write a command on the line, it will be activated even without typing
Some commands should be used with extreme caution, such as GPS, VPS and MANU
