Recommendations What drone keen semi pro photographer
Hi there everyone you probably been down this route so many times I apologise, so I am just about ready to take the plunge I have my registration done but what drone would people recommend for a keen semi pro photographer who will manipulate images in adobe media to create stuff as Nikon Z9 user I have looked at the Hasselblad Mavic 4 (expensive) the Air3S and the mini 4 I need good resolutions some stuff may be blown up to A2 A1 but I want to explore video art as well.
Could some kind people give me some advice
THANK YOU ALL in advance
Neil
Ps max budget would be £2000 but I would like less
For blowing up to A2 & A1 size, you will need a drone with camera capabilities that will allow the sort of fine definition that requires, especially if the image is to be scrutinised close-up. That will cost, but as a semi-pro photographer you may well not be deterred by this.
But, as you will have realised from your registration process, the restrictions on flying sub-250g drones (minis) are much less stringent than those heavier. I’d advise waiting until next January when sub-900g drones are to be included in the present sub-250g class, which will give you time to research the market. In the meantime, buy a Mini 4K to ‘get your hand in’; it’s capable of capturing images that can be blown to A4 without issue. Even when you buy a bigger drone, it will come in handy if, for example, you need to walk any distance to a site or travel by public transport. For indoor work, where the weight added by the propguards won’t matter (won’t matter outdoors in the new year, either), it will get into tighter spaces, an obvious advantage!
The Mavic 4 Pro would be great with three good, well-matched cameras, but above your budget. Maybe the Mavic 3 Pro, which will be getting steadily cheaper as it’s now been replaced. The main camera is a good honest 20MP 4/3 sensor, the two teles OK, but have been improved on the Mavic Pro 4. All the latest cameras are Quad Bayer mainly for high MP numbers in marketing. The Air 3S could be good, but I wasn’t happy with the colour artifacts for stills. It’s a neat package within your budget though, and probably a little easier to learn on if this is your first drone. The Minis are great, but ultimately limited in stills resolution (ignore the QB max resolutions).
Thank you
many thanks even comment is food for thought
I have both the Mini 4 Pro and Air 3S depending on where I fly. They are both excellent. What I do recommend in taking bracketed exposures and panoramas then stitching them as HDRs panos in Lightroom, or similar, to get really large amounts of detail. Good luck!
Thanks for the input
Can I ask what size is the raw file on the 3S, I presume it does raw I am a complete newbie to drones
Yes shoot RAW - I use the 12 Mega pixel setting but usually do a 3 shot HDR shot, often as part of a pano.
