Imagine you are all good, just happily flying your drone…
You hit the Return to home button…
And you think:
- “Alright, that’s it for today let’s relax a bit while my drone lands’’
And the drone, instead of landing where it should, it gets closer to the water and tries to land there.
Luckily you were paying attention and fastly hit the pause button…
But…
What just happened?
Well, each time you use the Return to the home button you might get a very different result to what you were expecting…
For example, you can cause the drone to go into landing exactly where it is!
If your drone is within 20 meters of home point and you press RTH it will not fly back to the home point but it will land where it is…
Even over water!!
And this applies to the Phantom 3, 4 and 4 Pro
Luckily for the Mavic DJI got a bit smarter and limited this to 5 meters.
So watch out when invoking RTH - you might be within the 20/5 meter trigger and go into landing where you are and this could be a COSTLY mistake!
