Since switching to D-Log, I followed the related instructions and turned contrast, saturation, and sharpness right down to -3.
I’m not having great results with the sharpness. When I bring it back up in post, I get “fuzzy” results, e.g. look at the building here:
I’ve experimented a bit, and to me I seem to get the best results by using sharpness 0, and then still applying sharpening in post, look at the wool cushion in:
Anything obvious I’m doing wrong? I don’t think it’s just bad focusing.
One thing I haven’t tried is sharpening in a different app. I’m using LumaFusion.
I’d only drop the contrast on the mp as it supposedly opens up the dynamic range. However you then need to use a LUT to correct it. If you try and add that back yourself (unless you’re a good colourist) you’ll introduce a bunch of noise which is what you’re seeing.
Different lut suppliers have different suggestions for these settings. For example, on the M2 film poets say - 3, spectrum grades are - 1 and polar pro are 0!
Though I’m now wondering if I properly understand what a LUT does - I thought it was just colour correction, so I would have assumed that any settings/post adjustments for sharpness would be independent of the LUT?
Also in the cushion video… I’m not applying any LUT - just sharpness setting, and the ‘cartoony’ effect is still there.
In any case I think the solution is not to drop the in-drone sharpening, but I’m still confused on the reasons.
