Thinking of using my Mavic 4 pro to take footage of the eclipse on weds. Unsure if to take video, ad hoc photos or hyperlapse. Im leaning towards hyperlapse, but unsure of the best settings. Temped just to leave it in auto, but I worry it’ll be naff.
My view is that any attempt to video or photograph the eclipse occlusion from a drone camera is going to be pretty pointless; the subject is going to be no more than a tiny dot on the screen even at full zoom! This is a job for a DSLR camera with a 600mm+ telophoto, and a serious tripod! If you are going to video the event, though, auto exposure is probably going to give you the best results…
What will be worth doing is filming the rapidly darkening sky, and, if you can get anywhere near the total occlusion path, the terrrifying sight of the Shadow of Doom hurtling across the surface of the Earth at 2,000mph or so from 400’ up!
The complete opposite is true. If videoing you’ll need to set to a manual exposure otherwise the camera will try to compensate for the darkening scene.
That’s exactly what you want though.
When I filmed the eclipse in Wyoming in 2017, I left all my cameras and the Drone on auto because the difference from partial to total coverage, is enormous and you’d end up with a blackout video during totality.
Ao instead of fretting about adjusting things manually, I just let the cameras readjust and the results came out perfectly…
I don’t think that would fry the sensor, especially if you use the main camera that doesn’t have any real magnification.
The sun will be very low in the sky similar to countless sunsets that I have videoed in the past, but crucially if you start filming just before totality the sun will be a fraction of its usual brightness and your sensor would be absolutely fine
True if you are trying to capture the sun itself, but if you want to capture the Sun and the shadow and the change in light for all the surroundings, then a drone would be absolutely fantastic
It won’t be any good for a close-up of the sun but it will be amazing to capture the changing light all around you
We’re not getting that in the UK though. Us lucky sods in Scotland will have 80-odd percent so it will just look like an overcast evening. So like usual then.
Ah true!!! So of course in that scenario, you’re absolutely right that you would want manual settings fixed so that you do get to see darkening… My bad.
Getting carried away down here in Soria, Spain, already in the path of totality
Like I said, within the UK much depends on how far south and west you can get. Totality tracks a curve starting on the Arctic coast of Russia, hangs a fairly sharp left to run down the Eastern Seaboard of Greenland, clips Iceland, misses the southwestern tip of Ireland but not by much, makes landfall in Galicia and a small portion of northern Portugal, and then runs across Spain to run out in the Med to it’s southeast. You lucky sod Ianinlondon! Porthcawl is set for a maximum of 94%, not total but a significant ‘bite’ out of the sun and significant dimming. so I’m reckoning on some worthwhile shots/footage of that. No point in bothering with the actual bodies unless you’re gonna get totality to my view, especially not what will be tiny spots in the drone frame! Porthcawl is a fairly easy bus ride, and the tide will be in as well. Bit of filming, chips in Beale’s, a beer, and last bus (21.35) home, all good stuff!
