TOAL from a canoe?
I’m considering a little venture in a canoe and wondered if anyone has any experience with TOAL from such. Hand launch would seem straight forward enough, but I’m wondering if a hand catch might be problematic, given that I won’t be a static object. I’ve had issues before trying to catch in long grass where the drone doesn’t like what’s underneath. Sensors off perhaps?
Maybe similar to This worth having a browse through .
If you do don’t forget to change your RTH set or take off from the bank just in case you loose signal lol
Thanks for the link Kirky, much appreciated. Now I just need to find a cheap canoe!
Here’s a start :rofl::+1:
Perfect, just 160km too far!!
Idea from left field.. 360 camera on a selfie stick, and other mounts. Way fmore flexibility , can the drone type shots anywhere and can even do the underwater shots as well
Yes, a good shout. I have looked at getting one. They do seem very handy. I have a GoPro and an extendable selfie stick for surface and underwater at the mo. The plan is to focus on medium range coastal filming with perhaps a bit of tracking added in
