Hi guys,
How do you transfer files from internal memory and SD card onto an iPad?
I have a Mavic Air and will be using my iPhone whilst flying but using my iPad for editing, so is it a case of using an iPad card reader or is there a direct way of transferring using WiFi or USB? I’m just exploring different options at the minute and like to hear your opinions.
while the drone,controller and ipad are all still hooked up,go into dji go 4 and tap editor and go into album option at the top,click the download icon (top left) this should give you acces to select files stored on the onboard sd card.
Files will download to iPad over your home WiFi, you don’t necessarily need a USB cable or adapter. The card reader won’t work to download files from card to iPad//iphone.
Neil
I’m using either my iPhone X or iPad Pro 10.5”
I bought a lightning to micro sd Card lead off Amazon.
It works every time, download time from card to device is ok, Only issue I have is available storage on the device or in iCloud.
I usually view files on my iPad then transfer via home WiFi to a large storage device connected to my router.
Works fine
That’s what I’ve ordered @mickydd so should be ok, I do have iCloud subscription already but if that fills up to easily I will get a network hdd as well, they are cheap enough these days for a couple of TB. Cheers mate
I’ve bought a card reader for £13 from amazon and I have an iPad Pro 12.9 which should be able handle 4K, so if it doesn’t work it’ll probably be because of the card reader. It has a usb connection on it aswell so that might work.
I just got myself a card reader in Delhi for £1 and does a perfect job putting the files I want from the micro sd card in the drone onto my laptop, I am using Android and Windows. I seem to have less problems than the guys using Apple.
