Right then clever clogs out there here’s the question
So I dropped my Pocket Master and now have to set the trim centre on the right stick all the way down to level it off and was looking to see if there was a way to re centre the trim centre on the remote where it is left like an override type thing
Anyways good excuse to the missus to look at a new new if needed ![]()
Put the trims in centre position, and then do a gimbal calibration. That should put everything back in order
If recalibration fails, you’ll have to invest in a set of these shiny sexy CNC Aluminium Gimbals. ![]()
Now you know you want a set. ![]()
On a serious note, take the back of radio (4 screws) and then check that the springed steel plate hasn’t bent or that nothing else hasn’t broken.
An adjustment may also be needed.
…and if you are really stuck, bring it to the BM ![]()
@Hotrodspike Thanks its on page 6 in settings ![]()
And nope its a rip the guts out and tinker time after much messing around the trims either fully up or down after recalibrating it really doesn’t want to reset or recentre so screwdrivers out tomorrow
@TheBinman might be a full upgrade at this rate ![]()
Upgraded Gimbals or Radio? ![]()
Or you could give me £120 for my TX15 in Blue, only used to set up a heli by @Steviegeek, else as new ![]()
Flashed back to factory settings
Firmware Updates – RadioMaster RC
And then
EdgeTX Buddy
Screw on the bar on the gimbal had come out
