You know…when you first bravely put on those Goggles, push up the throttle and then get immediately confronted by a crazed world of trees, sky, trees, sky and then a worryingly nearby whizz… “thunk” then a very close up view of some grass and an annoyed beetle
Well, just try switching your yaw and roll channels like i have just done when installing the DJI air unit! The magic is back…
Ohhhhhhh who thought terror could be so nostalgic?
Also, given the amount of cable ties I’ve had to use to attach the air unit to the frame… Does anyone know whether a caddx vista can melt a cable tie? Gets pretty hot…
And also, is there a regulation as to what percentage of your build can be cable ties before you’re officially flying a recycling container? 40%? 50%?
