I couldn’t believe the state of this, and how misleading the description is
https://www.ebay.co.uk/itm/164302127947
There is no way I’d touch that one!
10 foot, barge and pole springs to mind.
What astounded me the most is that the description implies that with a little bit of luck, and a small screwdriver in hand, you could fix it. It looks to me that half the body of the drone is missing!
Those missing parts are probably still up in the tree.
Must be worth it to someone - there’s a bid on it.
How much are new batteries> If someone wants another 3 for his Mini it may be worth it unless the amateur aircraft engineer has tried to “fix” them.
As maiden flights go… Epic!
I don’t even know what this means…
But anyway, I’ll leave it at this.
Even I wouldn’t touch it and I have a reputation for being attracted to slutty quads and those with daddy issues.
Nidge.
This just needs a quick polish. £350 starting bid? Bargain!
But it does say:
Delivered insured via DPD
Could always buy it for £350 then when it arrives send the photos to DPD and ask them what the fuck they did with it in transit
I think your post needs to be deleted asap.
Then we can bid on the kit and put your nefarious plan into operation …
(This message will self destruct in fifteen seconds)
