What do you do if you loose (or hopefully just mislay fingers & toes crossed)
These things seem like hens teeth! If you’ve ever tried to buy one. Use a ‘backward compatible’ type-c and you risk ruining the Controller socket. So what’s your solution?
Just use insolation tape and tape it to the charging lead, mark the upper side with a bright mark in order that you do not insert into the controller the wrong way, thus preventing damage, simple, quick, cheap and easy, has worked for me for about a year.
Thank you for your suggestions however Gaffer tape, sellotape, or any other types of tape along with blue tack and hot gun glue are not part of my tool/repair box for expensive electronic equipment presently and I continue to strive to find a more OEM type solution
