So, after the recent drowning of my MM2, though thoroughly dried out and operational, should I do/get done any maintenance of the movable parts? My thoughts go to water and iron(magnet) parts and such like which I presume are in the motors.
Was it fresh water? If so you should be fine. You’ve been pretty lucky to not damage any of the electronics. The motors are probably the things I’d worry about least of all. If you start trying to oil them or something then it’ll probably be counterproductive.
well if it was drowned in water then best just to use care refresh if you have itt
