When I was out last week what I thought was my battery sparking turned out to be the pigtail as it had rubbed on the frame through to the copper.
I was amazed as I wouldn’t of thought carbon fiber to be conductive
I realize this could of been an easy repair, A Bit Of Insulation Tap and off you go, but I decided to do a proper job i.e de solder the pigtail and slip some heat shrink over it
And that’s where it all went wrong, I have power to the FC and the Vista, my goggles have a feed but I have no controls i.e none of the switches work on my hand set.
To date, Iv linked the FC to Betaflight and flicked the mode switches and zero happens ?. Iv given the FC a good coat of looking at, and can only find a couple of anomalies as in the pictures below…
This is where my Vista plugs in, as you can see there seem to be 1 connector on the right that doesn’t seem normal, or is it
This is where I re soldered my pigtail back on Bit Of A Mess I Know, but as you can see I touched the said component with the iron slightly and got a little solder on it
Would anyone know what the said component is and could it be my issue ?? and is the connector supposed to be like that as I’m sure the end one isn’t used ???..
Many thanks
