Hey you wonderful people, with the new proposed changes in legislation I’m considering buying an additional drone and looking at either a mini 4 pro, mini 3 pro or an air 2s. I’m thinking with the air 2s, I already have a smart controller so would be a big cost save and being a C1 drone would mean post jan 2026 I could use it pretty much similar to a mini now. But then thinking with the mini 3 pro or 4 pro with respective RC controller would this be more future proofing if I upgrade again later for resell or comparability with the RC2 etc? Any help/advice is appreciated.
The Air 2S shipped with the DJI RC controller, it’s not compatible with drones that use the RC 2, nor will it be compatible with drones that use the RC 3 when that arrives.
DJI don’t want you future proofing yourself, they’re in the business of selling new drones and new controllers.
You spending less money in the future doesn’t bode well for their business plan ![]()
Don’t forget that any DJI drone on the market today, or before 31st December 2025 will not have a UK class mark on it, it’ll only have an EU class mark (if any).
The Mini 5 Pro will be here in a few weeks, is that an option? ![]()
Thanks, I know that C class is EU class marking but from my understanding of CAP3105 they will honour and convert these to the respective UK markings, although I may be misunderstanding that.
I know the Air 2s isn’t compatible with the RC controllers I more meant as it’s cheaper now (about half the price of the mini pro 4) and I already have a smart controller I could just use that with it until later down the line I upgrade (spend less now but have to spend more later). And with futureproofing my thought was more so with the mini pro 4 having the RC 2 if I want to get a larger drone later (upgrade the mavic 2 pro I have) I could get one compatible with it, maybe something like an Air 3S when they are cheaper. Budget won’t stretch to a mini 5 pro and not too fussed about having the latest drone just a decent one within a budget.
Hi, I currently have the mini 3Pro which is a great drone with both the RC-N1 and a recently purchased RC controller. Although it has forward, reward and downward obstacle sensing unlike the mini 4 pro with greater spread of the sensors it has a few things that the 4 is limited on. I use dronelink for mapped flying on the RC-N1 controller with great results but I understand it is not compatible/available with the 4 pro. Also from my understanding and comments online, under the new rules drones will need to use RID identification which the 3 pro has built in. The 4 pro only transmits identification if you use the larger battery which takes it over 249 grams. I hope this helps and suggest you check out the information before you buy. Finally if your budget is tight the Mini 3 pro is a great buy
This can be changed in software - it does transmit RID in other locations without the larger battery so they will just enable it in the UK when the rules change - DJI’s own website suggests that all their drones can do RID that were built after Sept 2020 I think it was ( when ever the mini 3Pro was launched ) the little Neo seems to be about the only one that may not support it - but thats only because in the US there is no need for it to have it due to their rule about sub 250g drones being flown for recreational use only not needed RID ( this also implies that the Neo cant be used to make money in the US
but its all software at the end of the day and if the hardware is in the device it can be turned on.
I’ve gone with the mini 4 pro fly more with the RC2, think it’s the safest bet in terms of future proofing and ability of what it can do. Thanks all for the advice and suggestions as always it’s appreciated.
