This is the Folly which was built by the Lord of the Manor (rumored to be his love nest to take his mistresses). I tried to capture the sunset which was quite spectacular, but I clearly failed. Any advice chaps?
Take the exposure reading from the sky (not a average reading for the whole frame) then adjust so it looks pretty on screen.
Or replace it post in Luminar or similar
Yep - that seems to have done the trick! Can’t help feeling I would be cheating though. I will have a play with the exposure readings. Thank you.
Does the Anafi shoot in RAW?
Apparently yes
I used to think of Photoshop as cheating (other photo software is available ), but if it’s good enough for professionals it’s good enough for me.
Apparently it does. I guess this would mean I could edit it easier?
It’d give you far more range and control over the edits and allow you to fix the sky quite easily
Okay thanks - I will look into it
