I am a Windows man really but bought an Mini i-Pad4 to use on my Mavic Mini. Getting on quite well with things but I have started to do Screen Recording on the i-Pad because it is sometimes useful after a flight to investigate height, position, etc. etc. My question is, how do I get the file that contains the screen recording onto my desktop ? I know where it is on the i-Pad and I have connected my i-Pad to the desktop pc using the charging cable but while the pc sees the i-Pad it doesn’t find any data on it.
I had a similar problem,and found that if i formatted a usb stick,on the desktop to FAT EX ,all data showed ok when transferring data to the usb on the ipad then the desktop pc read all data ok…just a thought…
I haven’t figured out how to quote answers in my replies so I will reply in the same order as comments received.
Thank you. Yes, I’ve already found them on the i-Pad.
Thank you. Sounds very useful but I would prefer to see where the drone was at the same time as the detail.
Thank you. Yes, I will try that.
Thank you. Forgive my ignorance but presume that I have to install Dropbox on the i-Pad first, then load it into that, and then install DB on the pc and I will find it ? I had thought that if I uploaded the screen recording to YouTube (I would make it an unlisted video) from the i-Pad then I would be able to see it from the pc.
Thanks to all of you for your time. Is there any way that I can “quote” in future replies on this site please ?
[quote=“PingSpike, post:9, topic:12442”]
You can highlight a section of text, and click on the “Quote” button that appears:
[/quote]That’s better than what I did a moment ago. Thank you.
Thank you. Have only ever used YT and have quite a few videos on there of one sort or another. I presume when they are in DropBox they can be downloaded for editing on my pc ? I use Cyberlink PowerDirector.
