Old Castle Rusins with a large Park area on both sides and plenty of Room to Manoeuvre. The castle grounds itself is fenced off with no access due to structural safety concerns.
The castle does Boarder a housing estate so caution should be used when flying over or close to private residence.
Good place for Beginners.
History Of Kerelaw Castle:
Kerelaw Castle is an altered massive ruined 13th- or 14th-century tower and courtyard, which is much overgrown. The basement was vaulted, and the building was remodelled in the 16th or 17th century.
Kerelaw was a property of the Lockharts in 1191, but later passed to the Campbells of Loudoun. The castle was built by the Cunningham Earls of Glencairn (Maxwelton), but was apparently destroyed (or sacked anyway) in a feud in 1488, and then sacked by the Montgomerys of Eglinton in 1528. Eglinton Castle was burned in retaliation. William Cunningham, 9th Earl, was active as a Covenanter, and led an unsuccessful rebellion against Cromwell’s occupation in 1653. He was made Chancellor of Scotland, after the Restoration, from 1661 to 1664.
The property had been sold to the Boyds in 1609, then to the Cunninghams of Cunninghamhead, before going to the Hamiltons in the middle of the 17th century. The ruined castle was remodelled around 1830 as a garden folly for Kerelaw or Grange House, an 18th-century mansion, which has itself been demolished, when large Gothic windows were inserted.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 17/04/2024. It remains the responsibility of any pilot to check for any changes before flying at the same location.
