03 air unit and V2 goggle osd issues
Here we go again… i had my V2s working perfectly with Betaflight osd and sneaky fonts with my caddx vista setup and wtfos.
Ive now added an 03 air unit to my collection, and I’d like to run this on one quad and the vista on another, same goggles.
So on the goggles I went into DJI fpv mode and flashed 01.04.00.00… so now I have option to switch to DJI 03 air unit, which is all good.
But now when I switch back to DJI digital fpv system to use the caddx - its binds OK but all my Sneaky Betaflight fonts have gone. Many are there but in DJI fonts, and all the radio rssi, dbi, LQ figures have gone. This firmware is on 01.00.0607
Any clues how i get my original OSD back?
the firmware update removed the hack that enables the WTFOS and fonts to be possible. pretty sure without rolling back the firmware and re applying the hack you won’t be able to use the fonts any more.
but then if you do that the O3 won’t work. so stuck between a rock and hard place unfortunately. it’s one or the other…
yeah @DeanoG60 is correct.
I had a similar dilemma last year but then purchased an Avata and the goggles integra which meant that i didn’t have to mess about so much.
May be worth looking for some goggles 2 or integra’s on ebay or similar. I’d bet they will have come down in price a bit now
Hmmmm… thats frustrating, I was so sure it woukd work with both.
I had a quick mess around on the wtfos website, reinstalled wtfos and the osd package. The OSD is back (albeit with slightly different HD font)
In the goggles menu the option to switch to 03 air unit is still there, and does switch over. But i haven’t gone anywhere near the 03 au, I guess this now won’t bind!
It will work just not with the wftos overlay sadly. I’ve used the goggles v2 for my avata and that works fine just not with the overlay (although that was a while ago and i have changed it since)
