Which is high compared to @Sparky at 100 iso
Just wondering which is the option - or would the lower iso give a different light on the cars?
Really not sure.
Really not sure.
As far as I am aware, with 360’s, DJI will automatically switch to manual anyway. I cannot remember in the above case whether I switched, or the drone did it automatically.
This is due to preventing “Auto” raising/lowering the exposure/ISO automatically for each of the 26 shots. If it did this, then some photos would be lighter/darker than others and make stitching impossible.
Regardless, when shooting 360s, day or night, you need to use the same ISO and exposure for each of the 26 shots. I am 99% sure that DJI sets it to manual automatically.
That depends on the scene. Both ISO and shutter speed (exposure) can lighten or darken the image.
But if you want some motion blur, you will need to increase the shutter speed, i.e. 1 second or more. So for night time shoots, with motion blur, the only option to lighten the image is increasing ISO. The downside of using ISO to bump the brightness is noise. But this can be reduced/remove in post.
I used a MIni 2 in Manual Mode but I normally use Auto this was just a quick test, i didn’t expect it come out as good but stitching the DNG files makes it far better
I am pretty sure the Mini 2 always switches to Auto on the 360 pano and you have to set it back to manual before you start the process
What i don’t understand is the Auto-rotate is not working on this DNG Pano
Kuula setting?
You can only use this feature when you use the “Share” option in Kuula. You can then change lots of settings on how you want the pano to display in forums, etc.
I’m guessing in the first image the app has also done its witchcraft enhancement. The sky is considerably more blue.
A load of sky files still available here if anyone wants them
I did all that, always do. The one above is on the same settings and that auto rotates
The one below doesn’t but it does work elsewhere
Bizarrely its working now!
Any chance of a copy I’ve just keep getting the trial version please for Windows
Do you have a windows copy
I will DM you later
Thank you
I would like the link to a working version for Windows if anyone would be so kind to DM to me pretty please…
I am a great fan of 360 panoramas and have investigated quite a few ways of sharing them online, for free. I have an Air 2S but previously used a Spark. Here is my current workflow using the JPGs from the SD card.
MS ICE is good too, very simple to use. Why use the JPGs though, and not the DNGs?
Below is a comparison using the same photo, but JPG left, and DNG right.
The DNG is better quality; sharper, less noise and more data.
Another DNG Pano edited tonight using some of the @clinkadink advice
I don’t really appreciate the benefit of DNGs for all the extra effort and size. They are typically 39MB vs 12MB JPGs and require an extra step and more time to colour grade and sharpen etc. Looking at your examples, in my opinion there are more details in the shadows of the JPG on the left.
But look at the noise
Any idea why Kuula is doing this to panos I’ve done today?
I’ve been stitching them auto Autopano Giga. Pretty sure I’m not missing a step, but it’s been that long maybe I am!
Taken with Mini 2.
I’ve tried doing the vertical alignment thing as detailed here but it does absolutely nothing.
Same result on Mac/Safari and Windows/Edge
