3D modelling by drone
Hi there! Before you post, have you selected the most appropriate category for your new topic? :thinking:
In addition to taking stereo photos, I sometimes like to create a 3D model of sites I have flown. I usually take a video while flying, so my source data is a 4K 60 fps video shot on my Air 3S.
There are a number of software packages available to make 3D models, but since I only do this occasionally, my choice is limited to those which have a workable, free option – I don’t like subscription models and I don’t use modelling enough to justify a constant outlay.
I identified four possibilities and to standardise the test I flew a Litchi waypoints mission at a favourite site and used its output to feed the modellers. I prefer Litchi because it flies a straight line where I want it to, rather than the wibbly-wobbly DJI routes:
… and it works!
Four programs were used to render the 3D model, all using the same video data:
WebODM
  • Had the poorest geometry of the four
  • Was fairly quick, but each task is deleted from the website after 2 days
  • Has a pay-per-model option if you need access to the full feature set
Polycam
  • Reliable and easy to use
  • Quite slow (say 40 mins) but good rendition
  • Free version has maximum of 150 still images or 3 minutes of video
SkyeBrowse
  • Quick rendering but not much height in the model
  • Monthly subscription is the only way to get pay-per-model
  • Free version is limited to two models
  • Allows you to view the source images as well as the model
MipMap
  • A PC program rather than a web app.
  • Free download of the program for local processing of video-based data
  • Free version allows you to generate up to 500 stills from your video, at a time interval you specify, so you can generate up to 500 images. Just remember to delete the files afterwards!
  • Slow processing (4 ½ hours!), obviously dependant on the speed of your PC. Maybe best run overnight.
  • Uses the .SRT subtitles file to geo-reference the images used.
  • Excellent detail and geometry in the 3D model, but a slightly quirky user interface to manipulate it on screen.
  • Model can be output in several formats, but is not available as a web page, so maybe less shareable than the others.
My first choice would be MipMap, followed by Polycam. Your mileage may vary.
Very interesting read and thank you for details.
Quick question.
The photos attached to the thread are all 2D, so I assume those are screen grabs.
Does the software produce a 3D image that can be explored freely by the viewer?
Yes. The first three are web apps, so the 3D tool is in a browser, and can be made available to anybody. MipMap exports 2D or 3D images in formats that can be played in other apps once you have emailed the file to the client.
As a commercial operator I pay for my subscriptions. I have to use cloud software as my laptop isn’t powerful enough for DJI Terra.
2 examples, click below.
Pix4DCloud
WEBODM
David
Latest Survey - Easby Abbey, Richmond
Great work Keitoi
Shame we live so far apart, I’m into scanning cultural heritage to make 3D models in the South West of England …
