Did manage to fly those new 8S batteries on my Era 5 and AOS 7 - even my wife noticed the grin on my face after the flights ![]()
Both quads have the ‘standard acro 6S kv’ motors (1750kv for the 5" and 1350kv for the 7") and while they are no slouch, I miss the extra push you get from higher kv’s (a 5" on 2000kv motors is something else
Enters the 8S batteries - giving you an extra 33% kv (I added a 90% limiter not to go overboard - so adding an extra 20% in the tests)
The batteries I got are quite heavier than the 6S I usually fly (6S/1400mAh @ 240g vs 8S/1380mAh @ 300g) - these are the smallest/lightest 8S made by Bonka (Tattu has some 1050mAh @ 240g - but no stock in the UK and they no longer ship here from Germany it seems…)
Big extra oomph in the punch out’s - and you can do lot more of them in the same flight without ruining flight time
hover throttle noticeably lower despite the extra weight
Quite a bit of extra speed at the same camera angle
Noticeable increase of ‘hang time’ - feels like I could do a 20-sides Rubik’s cube ![]()
I think the 5" may be even better with a slightly smaller battery (hopefully those Tattu’s will come back in stock at some point)
The 7" (with 3008 motors) seems to be in the perfect spot though - punching out like a 5" racer now despite the extra 140g ![]()
Here is the 7" test flight - I left the mic sound on for this one (I am somehow still in awe of the sound of a 7inch acro drone…)
