Hi
Does anyone have any recommendations for extended landing gear on an Air 3s. One of by favourite sites has long grass and is often quite gritty. I used PGYTech leg extenders on my Mavic 2 but I cant find anything similar for the air 3s
TIA
Hi
TIA
I made these but have never used them, I launch from my hand and land on my mat if the ground is wet
https://makerworld.com/en/models/596746?from=search#profileId-518781
What did you think of the leg extenders? I’m considering some for my M2Pro
I’ve got them on my 2 Zoom and very pleased with them. Just one point to be careful of - where the extenders attach to the drone arms - make sure they don’t slide along the arm and contact the outer bell of the motor - can cause some obvious problems but not an issue if you check before take off. They don’t move in flight but can slide along the arm when being stored ![]()
